September 17, 2010, 00:56 |
Bubble Foam momentum equation
Balkrishna Patankar
Rep Power: 17 |
I want to use the standard momentum equation in bubble Foam rather than the phase intensive one as suggested by Henrik Rusche in his PhD thesis... I got the following problems :
UEqns.H volVectorField Uamod = alpha*Ua ; volVectorField Ubmod = beta*Ub; fvVectorMatrix UaEqn(Ua, Ua.dimensions()*dimVol/dimTime); fvVectorMatrix UbEqn(Ub, Ub.dimensions()*dimVol/dimTime); { volTensorField Rca = -nuEffa*(fvc::grad(Ua)().T()); Rca = Rca + (2.0/3.0)*sqr(Ct)*I*k - (2.0/3.0)*I*tr(Rca); Rca = alpha*Rca ; surfaceScalarField phiRa = - fvc::interpolate(nuEffa) *mesh.magSf()*fvc::snGrad(alpha); UaEqn = ( (scalar(1) + Cvm*rhob*beta/rhoa)* ( fvm::ddt(Uamod) + fvm::div(phia,Uamod,"div(phia,Ua,alpha)") - fvm::Sp(fvc::div(phia,alpha), Ua) ) - fvm::laplacian(nuEffa,Uamod) + fvc::div(Rca) + fvm::div(phiRa,Ua,"div(phia,Ua)") - fvm::Sp(fvc::div(phiRa), Ua) + (fvc::grad(alpha)&Rca) == // g // Buoyancy term transfered to p-equation - fvm::Sp(alpha*beta/rhoa*dragCoef, Ua) // + beta/rhoa*dragCoef*Ub // Explicit drag transfered to p-equation - alpha*beta/rhoa*(liftCoeff - Cvm*rhob*DDtUb) ); UaEqn.relax(); Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.7.0 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phia,Uamod) Gauss limitedLinearV 1; div(phib,Ubmod) Gauss limitedLinearV 1; div(phia,Ua) Gauss limitedLinearV 1; div(phib,Ub) Gauss limitedLinearV 1; div(phib,k) Gauss limitedLinear 1; div(phib,epsilon) Gauss limitedLinear 1; div(phi,alpha) Gauss limitedLinear01 1; div((-nuEffa*grad(Ua).T())) Gauss linear; div((-nuEffb*grad(Ub).T())) Gauss linear; } laplacianSchemes { default none; laplacian(nuEffa,(alpha*Ua)) Gauss linear corrected; laplacian(nuEffb,(beta*Ub)) Gauss linear corrected; laplacian(nuEffa,Ua) Gauss linear corrected; laplacian(nuEffb,Ub) Gauss linear corrected; laplacian((rho*(1|A(U))),p) Gauss linear corrected; laplacian(DkEff,k) Gauss linear corrected; laplacian(DepsilonEff,epsilon) Gauss linear corrected; laplacian(DREff,R) Gauss linear corrected; laplacian(DnuTildaEff,nuTilda) Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } Code:
gradientInternalCoeffs cannot be called for a calculatedFvPatchField on patch inlet of field (alpha*Ua) in file "/home/ifmg/MySIM/CHECK/balBubbleFoam/bubbleColumn/0/(alpha*Ua)" You are probably trying to solve for a field with a default boundary condition. From function calculatedFvPatchField<Type>::gradientInternalCoeffs() const in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 186. |
September 17, 2010, 04:29 |
Laurence R. McGlashan
Rep Power: 23 |
Are you sure about doing this? There are some very good reasons for dividing the momentum equation by the phase fraction! Alberto Passalacqua was working on this, have a read through this thread:
Conservative Two Phase Euler The error is probably due to the boundary condition not being explicitly stated. You can either setup the Uamod field in the 0/folder, use the == operator instead of = (not sure if that works... try it) or Code:
volVectorField Uamod ( IOobject ( "Uamod", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), 1.0, Ua.boundaryField().types() );
Laurence R. McGlashan :: Website |
September 17, 2010, 04:33 |
Balkrishna Patankar
Rep Power: 17 |
thanks for the link ....
September 17, 2010, 04:40 |
Balkrishna Patankar
Rep Power: 17 |
I read the same arguments in Dr. Rusche's thesis .... The doubt I had was what is exactly meant by equations becoming singular ... I didnt quite understand the effect it would have on the flow ... For the same purpose , I decided to implement momentum eqn in the conservative form and check out how it affected the solution .....
Another doubt I face is : How is the non conservative form of the momentum equation derived ? i.e. how is it possible to divide by alpha when alpha is a variable in itself .... |
September 17, 2010, 04:48 |
Rep Power: 23 |
Another link in case you haven't spotted it is the bubbleFoam wiki article. Again, thanks to Alberto.
I haven't got first hand experience of the difficulties you'll encounter, but effectively in areas where the phase fraction is zero, your momentum becomes zero and the velocity becomes undefined. The matrix probably becomes ill conditioned. I have a full derivation. If you want to see how to get it for yourself, just expand the derivatives in the momentum equation and then divide the whole equation by its phase fraction.
September 17, 2010, 04:50 |
Rep Power: 23 |
I just spotted that your UaEqn/UbEqn should have Uamod and Ubmod as the variable to solve for, not Ua and Ub. There may be other mistakes.
September 18, 2010, 05:03 |
Balkrishna Patankar
Rep Power: 17 |
Have you shared (made it open source ) the PEA source code ???
September 20, 2010, 12:04 |
#9 |
Balkrishna Patankar
Rep Power: 17 |
I have started working on the same ..... right now working on two things ...
A spalding approach to calculate the volume fractions and the second one being the PEA ... Have completed the first one ... and will start the second part soon .... How are you programming the PEA ? As a general elimination algorithm or hard coding it ... Last edited by balkrishna; September 20, 2010 at 12:04. Reason: appropriate question |
September 20, 2010, 12:09 |
#10 |
Rep Power: 23 |
The PEA is Spalding's approach, no? That's the method where you substitute one momentum equation into the other and rearrange.
I created a multiphase PISO abstract class and have semiImplicit/partialElimination/multiphasePartialElimination derived classes. I don't think you need the PEA for bubbles. It's only necessary when the drag force is large, which is true for small particles in fluidised beds.
September 20, 2010, 12:21 |
#11 |
Balkrishna Patankar
Rep Power: 17 |
I meant the spalding approach to solving the volume fraction ... discretise the volume fraction eqns and then calculate alpha = alphadis/(alphadis + betadis) where alphadis and betadis are the discretized volume fraction eqns ...
September 23, 2010, 02:17 |
#12 |
Balkrishna Patankar
Rep Power: 17 |
I have come up with an implementation of the PEA .. .....
The equations i have used are on this page ... https://sites.google.com/site/balkrishnanitt/eq Can anyone tell me whether the implementation is correct .... Code:
fvVectorMatrix UaEqn(Ua, Ua.dimensions()*dimVol/dimTime); fvVectorMatrix UbEqn(Ub, Ub.dimensions()*dimVol/dimTime); { volTensorField Rca = -nuEffa*(fvc::grad(Ua)().T()); Rca = Rca + (2.0/3.0)*sqr(Ct)*I*k - (2.0/3.0)*I*tr(Rca); surfaceScalarField phiRa = - fvc::interpolate(nuEffa) *mesh.magSf()*fvc::snGrad(alpha)/fvc::interpolate(alpha + scalar(0.001)); UaEqn = ( (scalar(1) + Cvm*rhob*beta/rhoa)* ( fvm::ddt(Ua) + fvm::div(phia, Ua, "div(phia,Ua)") - fvm::Sp(fvc::div(phia), Ua) ) - fvm::laplacian(nuEffa, Ua) + fvm::div(phiRa, Ua, "div(phia,Ua)") - fvm::Sp(fvc::div(phiRa), Ua) == - beta/rhoa*(liftCoeff - Cvm*rhob*DDtUb) ); UaEqn.relax(); volTensorField Rcb = -nuEffb*fvc::grad(Ub)().T(); Rcb = Rcb + (2.0/3.0)*I*k - (2.0/3.0)*I*tr(Rcb); surfaceScalarField phiRb = - fvc::interpolate(nuEffb) *mesh.magSf()*fvc::snGrad(beta)/fvc::interpolate(beta + scalar(0.001)); UbEqn = ( (scalar(1) + Cvm*rhob*alpha/rhob)* ( fvm::ddt(Ub) + fvm::div(phib, Ub, "div(phib,Ub)") - fvm::Sp(fvc::div(phib), Ub) ) - fvm::laplacian(nuEffb, Ub) + fvm::div(phiRb, Ub, "div(phib,Ub)") - fvm::Sp(fvc::div(phiRb), Ub) == + alpha/rhob*(liftCoeff + Cvm*rhob*DDtUa) ); UbEqn.relax(); volScalarField beta12 = alpha/rhoa*dragCoef ; volScalarField beta21 = alpha/rhob*dragCoef ; volScalarField denomA = UaEqn.A()*UbEqn.A() + UbEqn.A()*beta12 +UaEqn.A()*beta21 ; volScalarField denomB = UbEqn.A()*UaEqn.A() + UbEqn.A()*beta12 +UaEqn.A()*beta21 ; Ua = ((UbEqn.A()+beta21)*(UaEqn.H()- fvc::div(Rca)-(fvc::grad(alpha)/(fvc::average(alpha) + scalar(0.001)) & Rca) + g) + beta12 * (UbEqn.H() - fvc::div(Rcb)-(fvc::grad(beta)/(fvc::average(beta) + scalar(0.001)) & Rcb) + g) ) / denomA ; Ub = ((beta21)*(UaEqn.H()- fvc::div(Rca)-(fvc::grad(alpha)/(fvc::average(alpha) + scalar(0.001)) & Rca)+g) + (UaEqn.A() + beta12) * (UbEqn.H() - fvc::div(Rcb)-(fvc::grad(beta)/(fvc::average(beta) + scalar(0.001)) & Rcb)+g) ) / denomB ; } Last edited by balkrishna; September 23, 2010 at 04:08. Reason: Improper description of solution method ... |
September 23, 2010, 04:01 |
#13 |
Rep Power: 23 |
The equations are not in that link. Best to check those before code.
You're not solving the equations simultaneously, you're eliminating the other phase's velocity from each velocity equation.
September 27, 2010, 04:11 |
#14 |
Balkrishna Patankar
Rep Power: 17 |
I am getting the following error ... How can it be resolved ??
<code> --> FOAM FATAL ERROR: incompatible fields for operation [Ubmod] == [Ub] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) in file /home/ifmg/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvMatrix.C at line 1181. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so" #2 #3 #4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #5 Aborted </code> When is the function checkMethod executed ?? |
October 19, 2012, 04:08 |
#15 |
Rep Power: 14 |
Not very relevant to the original poster's problem, but I'd like to have make sure about something in bubblefoam momentum equation.
surfaceScalarField phiRa = - fvc::interpolate(nuEffa) *mesh.magSf()*fvc::snGrad(alpha)/fvc::interpolate(alpha + scalar(0.001)); If yes, then why not VSMALL but a random scalar number? |
#16 |
Rep Power: 14 |
October 19, 2012, 07:48 |
#17 |
Anton Kidess
Rep Power: 29 |
I guess that if you'd use VSMALL, you'd end up with a huge number if alpha1 is indeed zero. To avoid problems the authors chose a small, but not too small value.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
November 23, 2012, 08:47 |
#18 |
Rep Power: 14 |
But what if the alpha values that I am working with are also small? smaller than 0.001? then this hard-coded value will affect my results?
should I decrease this scalar value only few order of magnitudes then? |
September 23, 2010, 04:06 |
#19 |
Balkrishna Patankar
Rep Power: 17 |
I have updated the link ....
September 17, 2010, 04:51 |
#20 |
Balkrishna Patankar
Rep Power: 17 |
can u send me a link to the derivation .... thanks ...
bubblefoam, equations, momentum |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
Derivation of Momentum Equation in Integral Form | Demonwolf | Main CFD Forum | 2 | October 29, 2009 19:53 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
