Bubble Foam momentum equation
Old   September 17, 2010, 00:56
Default Bubble Foam momentum equation
Balkrishna Patankar
balkrishna is on a distinguished road
I want to use the standard momentum equation in bubble Foam rather than the phase intensive one as suggested by Henrik Rusche in his PhD thesis... I got the following problems :
UEqns.H
volVectorField Uamod = alpha*Ua ;
volVectorField Ubmod = beta*Ub;
fvVectorMatrix UaEqn(Ua, Ua.dimensions()*dimVol/dimTime);
fvVectorMatrix UbEqn(Ub, Ub.dimensions()*dimVol/dimTime);
    volTensorField Rca = -nuEffa*(fvc::grad(Ua)().T());
    Rca = Rca + (2.0/3.0)*sqr(Ct)*I*k - (2.0/3.0)*I*tr(Rca);
    Rca = alpha*Rca ;
    surfaceScalarField phiRa =
      - fvc::interpolate(nuEffa)
       *mesh.magSf()*fvc::snGrad(alpha);
    UaEqn =
        (scalar(1) + Cvm*rhob*beta/rhoa)*
            fvm::ddt(Uamod)
            + fvm::div(phia,Uamod,"div(phia,Ua,alpha)")
            - fvm::Sp(fvc::div(phia,alpha), Ua)
        - fvm::laplacian(nuEffa,Uamod)
        + fvc::div(Rca)
      + fvm::div(phiRa,Ua,"div(phia,Ua)")
      - fvm::Sp(fvc::div(phiRa), Ua)
      + (fvc::grad(alpha)&Rca)
    //  g                        // Buoyancy term transfered to p-equation
      - fvm::Sp(alpha*beta/rhoa*dragCoef, Ua)
    //    + beta/rhoa*dragCoef*Ub    // Explicit drag transfered to p-equation
      - alpha*beta/rhoa*(liftCoeff - Cvm*rhob*DDtUb)
    UaEqn.relax();
This compiles fine but I am not able to run it . The fvSchemes file is modified as follows :
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phia,Uamod)    Gauss limitedLinearV 1;
    div(phib,Ubmod)    Gauss limitedLinearV 1;
    div(phia,Ua)    Gauss limitedLinearV 1;
    div(phib,Ub)    Gauss limitedLinearV 1;
    div(phib,k)     Gauss limitedLinear 1;
    div(phib,epsilon) Gauss limitedLinear 1;
    div(phi,alpha)  Gauss limitedLinear01 1;
    div((-nuEffa*grad(Ua).T())) Gauss linear;
    div((-nuEffb*grad(Ub).T())) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEffa,(alpha*Ua)) Gauss linear corrected;
    laplacian(nuEffb,(beta*Ub)) Gauss linear corrected;
    laplacian(nuEffa,Ua) Gauss linear corrected;
    laplacian(nuEffb,Ub) Gauss linear corrected;
    laplacian((rho*(1|A(U))),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
This gives the following error .... what can be done to correct this ???
    gradientInternalCoeffs cannot be called for a calculatedFvPatchField
    on patch inlet of field (alpha*Ua) in file "/home/ifmg/MySIM/CHECK/balBubbleFoam/bubbleColumn/0/(alpha*Ua)"
    You are probably trying to solve for a field with a default boundary condition.
    From function calculatedFvPatchField<Type>::gradientInternalCoeffs() const
    in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 186.
Any suggestion to overcoming this problem ...
balkrishna is offline   Reply With Quote
Old   September 17, 2010, 04:29
Laurence R. McGlashan
l_r_mcglashan will become famous soon enough
Are you sure about doing this? There are some very good reasons for dividing the momentum equation by the phase fraction! Alberto Passalacqua was working on this, have a read through this thread:
Conservative Two Phase Euler
The error is probably due to the boundary condition not being explicitly stated. You can either setup the Uamod field in the 0/folder, use the == operator instead of = (not sure if that works... try it) or
            IOobject
                "Uamod",
                runTime.timeName(),
                mesh,
                IOobject::NO_READ,
                IOobject::AUTO_WRITE
            1.0,
            Ua.boundaryField().types()
Laurence R. McGlashan :: Website
l_r_mcglashan is offline   Reply With Quote
Old   September 17, 2010, 04:33
Balkrishna Patankar
thanks for the link ....
Old   September 17, 2010, 04:40
Balkrishna Patankar
I read the same arguments in Dr. Rusche's thesis .... The doubt I had was what is exactly meant by equations becoming singular ... I didnt quite understand the effect it would have on the flow ... For the same purpose , I decided to implement momentum eqn in the conservative form and check out how it affected the solution .....
Another doubt I face is :
How is the non conservative form of the momentum equation derived ? i.e. how is it possible to divide by alpha when alpha is a variable in itself ....
Old   September 17, 2010, 04:42
Balkrishna Patankar
Presently I am getting the following error on running the program :
 FOAM FATAL ERROR:
incompatible fields for operation
    [Ua] - [Uamod]
    From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&)
    in file /home/ifmg/OpenFOAM/OpenFOAM-1.7.0/src/finiteVolume/lnInclude/fvMatrix.C at line 1181.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#5  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Aborted
Old   September 17, 2010, 04:48
Another link in case you haven't spotted it is the bubbleFoam wiki article. Again, thanks to Alberto.
I haven't got first hand experience of the difficulties you'll encounter, but effectively in areas where the phase fraction is zero, your momentum becomes zero and the velocity becomes undefined. The matrix probably becomes ill conditioned.
I have a full derivation. If you want to see how to get it for yourself, just expand the derivatives in the momentum equation and then divide the whole equation by its phase fraction.
Old   September 17, 2010, 04:50
I just spotted that your UaEqn/UbEqn should have Uamod and Ubmod as the variable to solve for, not Ua and Ub. There may be other mistakes.
Old   September 17, 2010, 04:51
Balkrishna Patankar
can u send me a link to the derivation .... thanks ...
Old   September 17, 2010, 05:24
Balkrishna Patankar
got it!!! derived it myself ... but are there cases when using a non conservative form for multiphase flow may result in spurious results ...
Old   September 18, 2010, 05:03
Balkrishna Patankar
Have you shared (made it open source ) the PEA source code ???
Old   September 20, 2010, 11:36
Not yet, maybe soon!
Old   September 20, 2010, 12:04
Balkrishna Patankar
I have started working on the same ..... right now working on two things ...
A spalding approach to calculate the volume fractions and the second one being the PEA ... Have completed the first one ... and will start the second part soon ....
How are you programming the PEA ? As a general elimination algorithm or hard coding it ...
Last edited by balkrishna; September 20, 2010 at 12:04. Reason: appropriate question
Old   September 20, 2010, 12:09
The PEA is Spalding's approach, no? That's the method where you substitute one momentum equation into the other and rearrange.
I created a multiphase PISO abstract class and have semiImplicit/partialElimination/multiphasePartialElimination derived classes.
I don't think you need the PEA for bubbles. It's only necessary when the drag force is large, which is true for small particles in fluidised beds.
Old   September 20, 2010, 12:21
Balkrishna Patankar
I meant the spalding approach to solving the volume fraction ... discretise the volume fraction eqns and then calculate alpha = alphadis/(alphadis + betadis) where alphadis and betadis are the discretized volume fraction eqns ...
Old   September 23, 2010, 02:17
Balkrishna Patankar
I have come up with an implementation of the PEA .. .....
The equations i have used are on this page ... https://sites.google.com/site/balkrishnanitt/eq
Can anyone tell me whether the implementation is correct ....
       *mesh.magSf()*fvc::snGrad(alpha)/fvc::interpolate(alpha + scalar(0.001));
    UaEqn =
            fvm::ddt(Ua)
          + fvm::div(phia, Ua, "div(phia,Ua)")
          - fvm::Sp(fvc::div(phia), Ua)
      - fvm::laplacian(nuEffa, Ua)
      + fvm::div(phiRa, Ua, "div(phia,Ua)")
      - beta/rhoa*(liftCoeff - Cvm*rhob*DDtUb)
    UaEqn.relax();
    volTensorField Rcb = -nuEffb*fvc::grad(Ub)().T();
    Rcb = Rcb + (2.0/3.0)*I*k - (2.0/3.0)*I*tr(Rcb);
    surfaceScalarField phiRb =
       - fvc::interpolate(nuEffb)
        *mesh.magSf()*fvc::snGrad(beta)/fvc::interpolate(beta + scalar(0.001));
    UbEqn =
        (scalar(1) + Cvm*rhob*alpha/rhob)*
            fvm::ddt(Ub)
          + fvm::div(phib, Ub, "div(phib,Ub)")
          - fvm::Sp(fvc::div(phib), Ub)
      - fvm::laplacian(nuEffb, Ub)
      + fvm::div(phiRb, Ub, "div(phib,Ub)")
      - fvm::Sp(fvc::div(phiRb), Ub)
      + alpha/rhob*(liftCoeff + Cvm*rhob*DDtUa)
    UbEqn.relax();
    volScalarField beta12 = alpha/rhoa*dragCoef ;
    volScalarField beta21 = alpha/rhob*dragCoef ;
    volScalarField denomA = UaEqn.A()*UbEqn.A() + UbEqn.A()*beta12 +UaEqn.A()*beta21 ;
    volScalarField denomB = UbEqn.A()*UaEqn.A() + UbEqn.A()*beta12 +UaEqn.A()*beta21 ;
    Ua = ((UbEqn.A()+beta21)*(UaEqn.H()- fvc::div(Rca)-(fvc::grad(alpha)/(fvc::average(alpha) + scalar(0.001)) & Rca) + g)
          + beta12 * (UbEqn.H() -  fvc::div(Rcb)-(fvc::grad(beta)/(fvc::average(beta) + scalar(0.001)) & Rcb) + g) ) / denomA ;
    Ub = ((beta21)*(UaEqn.H()- fvc::div(Rca)-(fvc::grad(alpha)/(fvc::average(alpha) + scalar(0.001)) & Rca)+g)
          + (UaEqn.A() + beta12) * (UbEqn.H() -  fvc::div(Rcb)-(fvc::grad(beta)/(fvc::average(beta) + scalar(0.001)) & Rcb)+g) ) / denomB ;
Its still premature ... hence a bit messy ... sry for that ...
Last edited by balkrishna; September 23, 2010 at 04:08. Reason: Improper description of solution method ...
Old   September 23, 2010, 04:01
The equations are not in that link. Best to check those before code.
You're not solving the equations simultaneously, you're eliminating the other phase's velocity from each velocity equation.
Old   September 23, 2010, 04:06
Balkrishna Patankar
I have updated the link ....
Old   September 27, 2010, 04:11
Balkrishna Patankar
I am getting the following error ... How can it be resolved ??
<code>
--> FOAM FATAL ERROR:
[Ubmod] == [Ub]
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ifmg/OpenFOAM/OpenFOAM-1.7.0/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Aborted
</code>
When is the function checkMethod executed ??
Old   October 19, 2012, 04:08
mikeP is on a distinguished road
Not very relevant to the original poster's problem, but I'd like to have make sure about something in bubblefoam momentum equation.
 surfaceScalarField phiRa =       - fvc::interpolate(nuEffa)        *mesh.magSf()*fvc::snGrad(alpha)/fvc::interpolate(alpha +         scalar(0.001));
As I understand, scalar(0.001) is there to avoid division by zero. Is that correct?
If yes, then why not VSMALL but a random scalar number?
mikeP is offline   Reply With Quote
bubblefoam, equations, momentum
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
