November 5, 2015, 13:30 |
changes of files between openfoam versions
Przemek
Rep Power: 15 |
Hi Foamers,
I have a question how to find which files were replaced in the newer versions of OpenFOAM. I mean the following situations: I have solver which was dedicated to OF2.1.1. I try to compile this on OF2.3.0 but it needs hsCombustionThermo.H file. But in the OF2.3.0 version there is no such a file. How can I find out how this part of the code was replaced?
best regards pblasiak |
November 13, 2015, 15:26 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Check my combo repository: https://github.com/wyldckat/OpenFOAM-combo/
You will need to git clone it first and then git checkout the "combo" branch. For example: Code:
cd ~/OpenFOAM git clone https://github.com/wyldckat/OpenFOAM-combo.git cd OpenFOAM-combo git checkout combo Code:
git checkout combo-version-2.1.1 find src -name hsCombustionThermo.H gitk --all src/thermophysicalModels/reactionThermo/combustionThermo/hsCombustionThermo/hsCombustionThermo.H So we checkout out the closest version and use gitk to inspect the evolution of the remaining folder: Code:
git checkout combo-version-2.2.1 gitk src/thermophysicalModels/reactionThermo/ Essentially, the file you're looking for was replaced by either a "rho" or a "psi" implementation. For more details we check the release notes on this topic: http://www.openfoam.org/version2.2.0/thermophysical.php |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Can different OpenFOAM versions share the same ParaView? | kiddmax | OpenFOAM Installation | 4 | July 23, 2021 09:20 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
about the additional output files when using CrankNicholson or backward in Openfoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 0 | August 30, 2014 10:08 |
OpenFOAM Foundation releases OpenFOAM 2.2.2 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 0 | October 14, 2013 07:18 |
