[swak4Foam] funkySetBoundaryField "create" entry
Old   March 29, 2016, 05:25
Default funkySetBoundaryField "create" entry
Timm Severin
Astrodan is on a distinguished road
Servus everyone,
for whoever might use it, I recently needed to apply the funkySetBoundaryField utility from swak4Foam to a nonexistent field, which does not work.
You could just copy an arbitrary existing field, but that would not be very dynamic. So attached you find a patch for the funkSetBoundaryField.C located in swak4Foam/Utilities/funkySetBoundaryField which takes care of creating a new field if the "create" keyword is set in the corresponding dictionary (similar to the funkySetField keyword, however performance is probably not that good, since I just write a new temporary, empty field before reading it again).
So far,
-Timm
Edit: Updated the patch, now it also accepts the entry type scalar or type vector as an expression to either create a volScalarField or a volVectorField.
Astrodan is offline   Reply With Quote
funkysetboundaryfield, swak4foam
create the file *.foam phongstar OpenFOAM 12 October 14, 2018 18:06
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[gmsh] How to create a 3D volume mesh using a existing surface mesh?! RobertHB Mesh Generation & Pre-Processing 0 July 20, 2017 08:12
Problem in3D model processing mebinitap OpenFOAM 2 December 12, 2014 04:40
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer seal2013 ANSYS Meshing & Geometry 3 October 6, 2013 16:09
