September 20, 2011, 11:27 |
pisoFoam fails with locDynOneEqEddy
Rep Power: 16 |
pisoFoam crashes when I try to use the locDynOneEqEddy LES model.
libOpenFOAM.so and libincompressibleRASModels.so both show up in the attached log. When I run the case with say dynSmagorinsky, everything works fine. in my constant/LESProperties: *************************************** LESModel locDynOneEqEddy delta cubeRootVol; locDynOneEqEddyCoeffs { ce 1.05; filter simple; } **************************************** I have no issues with this turb model in a channel flow problem with both pisoFoam and channelFoam. I have checked the initial conditions several times but I cannot find anything that could be responsible for crash in this case. Any hints are appreciated. |
December 29, 2011, 19:42 |
Tarak
Rep Power: 15 |
Hii,
You can try to solve this in 2 ways: 1. In the wall boundary condition for turbulent kinetic energy, give a very small value e.g 1e-20 instead of 0. OR 2. Start solution using oneEqEddy or dynOneEqEddy model (or any other simpler model) and after some hundreds of iterations switch to locDynOneEqEddy model. Thanks, Tarak |
March 17, 2014, 11:32 |
Rep Power: 12 |
Hi Tarak,
Your response for gfilip's question interested me alot. May you give me more details of switching to locDynOneEqEddy model after hundreds of iterations? More generally, I am searching how to initialize a LES simulation from a known solution? Thank in advance, VUT |
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam | mchurchf | OpenFOAM | 7 | August 6, 2023 09:12 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
Trouble migrating oodles to pisoFoam while changing from OF 1.5 to 1.7 | sebi | OpenFOAM | 0 | December 7, 2010 09:00 |
Grid Check Fails in Parallel Processing Mode | askance | Main CFD Forum | 0 | October 20, 2010 10:11 |
the result of pitzDaily using simpleFoam and pisoFoam | Kr_kim | OpenFOAM Running, Solving & CFD | 1 | March 16, 2010 13:38 |
