Numerical schemes available in OF 2.x
Old   January 18, 2013, 10:51
Default Numerical schemes available in OF 2.x
Simone
batta31 is on a distinguished road
Hi guys! Is there a page where I can find all or almost all the numerical schemes available in OF 2.x? I can only find posts with previous versions of OF but also the syntax has been changed through the new versions. I'd really need it because I'm troubling with a very sensitive simulation which doesn't converge.
Any help is REALLY appreciated.
Cheers
Simone
batta31 is offline   Reply With Quote
Old   January 19, 2013, 08:23
Daniele Vicario
danvica is on a distinguished road
Just in case, this is a good starting point: http://www.openfoam.org/docs/user/fv...#x20-1070004.4
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Old   January 19, 2013, 08:30
Simone
Hi Danvica,
thank you for your answer..actually I've already read that page but I'm looking for something more detailed, especially about ALL the schemes available. Notice that for gradSchemes just a little of them are explained in the page that you suggest but actually there are many more availlable..The point is that I can't find the usage of each of them..
Old   January 19, 2013, 09:00
Daniele Vicario
I'm not sure but I don't think there's a single document explaining all, i doubt that for many it exist even a small doc.
Did you try in the past workshop papers ? You can find lots of interesting info here and there...
Daniele Vicario
Old   January 19, 2013, 10:19
Simone
Where can I find them? On this forum?
Old   January 20, 2013, 08:16
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Simone,
You can give the name of a scheme that doesn’t exist and OpenFOAM will give an error message with all available schemes. At least you will know the name of the schemes.
Regards,
Paulo
vatavuk is offline   Reply With Quote
Old   January 21, 2013, 04:16
Simone
Hi Paulo thanks for your anwer, I've already experienced what you're saying. I'm really starting to think that what I'm looking for doesn't exist..
Old   January 22, 2013, 11:04
Kevin Smith
kev4573 is on a distinguished road
I've never seen a comprehensive detailed explanation of all the numerical schemes, although you may be able to piece together something from the c++ documentation. Before going down that rabbit hole, I'd suggest verifying your mesh and boundary conditions are good; most stability issues usually stem from those two in my experience.
kev4573 is offline   Reply With Quote
Old   January 23, 2013, 07:48
Elvis
elvis will become famous soon enough
there was the desire to work on s.th you are looking for
http://www.cfd-online.com/Forums/openfoam/69068-foam-documentation-project-shut-down.html but this attempt was stopped!
i guess the mentioned workshop http://www.openfoamworkshop.org/2012/OFW7_Program.html
http://openfoam-extend.sourceforge.n...W7_Former.html
OF-related PHD thesises http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/docs/
there is also http://www.tfd.chalmers.se/~hani/kurser/OS_CFD/
elvis is offline   Reply With Quote
Old   January 23, 2013, 08:02
Daniele Vicario
I'm sorry not be able to help with solvers documents.
Some weeks ago I found a post containing the direct links to all past Workshops papers... but I don't remember where and whom
The link http://www.openfoamworkshop.org/2012/OFW7_Former.html is pointing to "Page Not Found"...
Do you know others links ?
Daniele Vicario
Old   January 23, 2013, 08:06
Elvis
Hi
https://github.com/OpenFOAM/OpenFOAM...e/finiteVolume
convectionSchemes d2dt2SchemesddtSchemesdivSchemesfvfvSchemesfvSolutionfvcfvmgradSchemeslaplacianSchemessnGradSchemes
Old   January 23, 2013, 12:41
Daniele Vicario
Many Thanks !
Daniele Vicario
Numerical schemes for free surface flows (VOF) botp OpenFOAM 2 March 11, 2011 15:27
numerical schemes Valerio FLUENT 2 July 28, 2008 04:02
Kinetic schemes and numerical dissipation Praveen Main CFD Forum 0 September 6, 2002 07:09
Behaviour of Numerical Schemes Ravi. B. R Main CFD Forum 3 September 22, 2001 10:18
Standard for checking and testing numerical schemes? X. Ye Main CFD Forum 7 August 31, 1999 17:05
