April 10, 2013, 13:11 |
set the pressure BC by a table
Ehsan
Rep Power: 26 |
why totalPressure is set as this?
[CODEinlet { type uniformTotalPressure; pressure table ( (0 10) (1 40) ); p0 40; // only used for restarts U U; phi phi; rho none; psi none; gamma 1; value uniform 40; }][/CODE] in this link: https://github.com/OpenFOAM/OpenFOAM.../TJunction/0/p |
June 15, 2013, 22:42 |
shiv
Rep Power: 13 |
hi all,
I have the same doubt ?? Ehsan did u find the explanation for this? |
June 16, 2013, 05:03 |
Ehsan
Rep Power: 26 |
Hi
no I don't know why it has selected 40 for p0 and value while it starts with 10.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King. To Be or Not To Be,Thats the Question! The Only Stupid Question Is the One that Goes Unasked. |
June 16, 2013, 09:03 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
It's a tutorial, which is giving some hints on how to use "p0". The case is rather fast to run, so the idea is that the value "p0" is set to 40 because continuing the case will probably be after 1.0 s or 1.5s, at which point in time, it's already at 40, as indicated by the time table. In other words, it's so quick to run, that it's more likely to stop after 1.0 s, than anything else. Have a look at the "controlDict" to see what I mean. Best regards, Bruno
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
matching pressure drop with test set up | sieginc. | STAR-CCM+ | 2 | November 15, 2012 19:13 |
Env variable not set | gruber2 | OpenFOAM Installation | 5 | December 30, 2005 04:27 |
Pressure Inlet yields wrong velocities | Ben | FLUENT | 0 | November 21, 2004 01:47 |
Mass Flow Outlet | Glenn Price | FLUENT | 4 | May 30, 2000 14:02 |
