set the pressure BC by a table
Old   April 10, 2013, 13:11
Default set the pressure BC by a table
immortality's Avatar
Ehsan
immortality is on a distinguished road
why totalPressure is set as this?
[CODEinlet
type uniformTotalPressure;
pressure table
(0 10)
(1 40)
p0 40; // only used for restarts
U U;
phi phi;
rho none;
psi none;
gamma 1;
value uniform 40;
}][/CODE]
in this link:
https://github.com/OpenFOAM/OpenFOAM.../TJunction/0/p
immortality is offline   Reply With Quote
Old   June 15, 2013, 22:42
shiv
shash is on a distinguished road
hi all,
I have the same doubt ??
Ehsan did u find the explanation for this?
shash is offline   Reply With Quote
Old   June 16, 2013, 05:03
Ehsan
Hi
no I don't know why it has selected 40 for p0 and value while it starts with 10.
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
Old   June 16, 2013, 09:03
Retired Super Moderator
Bruno Santos
Greetings to all!
It's a tutorial, which is giving some hints on how to use "p0".
The case is rather fast to run, so the idea is that the value "p0" is set to 40 because continuing the case will probably be after 1.0 s or 1.5s, at which point in time, it's already at 40, as indicated by the time table.
In other words, it's so quick to run, that it's more likely to stop after 1.0 s, than anything else.
Have a look at the "controlDict" to see what I mean.
Best regards,
Bruno
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 10:08
matching pressure drop with test set up sieginc. STAR-CCM+ 2 November 15, 2012 19:13
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Pressure Inlet yields wrong velocities Ben FLUENT 0 November 21, 2004 01:47
Mass Flow Outlet Glenn Price FLUENT 4 May 30, 2000 14:02
