initial residual and final residual
Like Tree37Likes
  • 16 Post By Anne Lincke
  • 2 Post By Anne Lincke
  • 5 Post By Manm
  • 11 Post By blais.bruno
  • 3 Post By Manm
Old   May 9, 2013, 04:16
Default initial residual and final residual
Maosong Cheng
mscheng is on a distinguished road
Hi FOAMERs,
what is the definition of the initial residual and final residual, which can be used to decide convergence ?
mscheng is offline   Reply With Quote
Old   May 15, 2013, 05:20
Anne Gerdes
Anne Lincke is on a distinguished road
The initial residual is evaluated based on the current values of the field before solving an equation for a particular field . The final residual is evaluated after the solution of the equation is performed.
The intial residual is more important to decide whether a computation converges, or not.
Anne Lincke is offline   Reply With Quote
Old   May 15, 2013, 08:23
Timo K.
timo_IHS is on a distinguished road
Hi Anne,
can you give some rule of thumbs for values, which should be achieved for the initial/final residual and how many iterations should be used for pEqn per cycle e.g. for a transient simulation with a standard PCG solver.
Best Timo
timo_IHS is offline   Reply With Quote
Old   May 15, 2013, 08:29
Anne Gerdes
Initial residual: e^-4 or e^-5 is a good result. Final residual has to be smaller (e^-8).
I cannot answer your 2nd question.
lf.lopez18 and wht like this.
Old   August 17, 2016, 15:45
Manm
Manm is on a distinguished road
Hi, based on this definition, I was curious as to why the final residual in one time step NOT equal to initial residual in NEXT time step?
Manm is offline   Reply With Quote
Old   August 17, 2016, 15:55
Bruno Blais
blais.bruno is on a distinguished road
Assuming you are solving in steady state, it is because the equations are non-linear.
If you solve the momentum equation for U, at the next iteration, P and phi will have been changed. Therefore, the initial residual will be different from the final residual of the last iteration.
If you were to solve a linear equation, non-coupled with any other variables, in steady-state, then you would solve it in a single iteration... and therefore your "next initial" residual would be your last final one...
blais.bruno is offline   Reply With Quote
Old   August 17, 2016, 17:13
Manm
Thank you. That helped to understand my question.
If I understand it right,
Say : U =f(p,phi,t) where f is a complex function
If t0 =0:
During 1 st iteration, we start with a p0, phi0 and dt time step and get U1 =f(p0, phi0,dt) as well as p1, phi1 values. The corresponding final error/ residual is calculated from U1 and true U expected.
Before 2nd iteration starts, a (say) U12 is calculated based on new available values:
U12 =f(p1,phi1,dt) and this is used to calculate the initial error/ residual before the 2nd time step starts.
and then we go on to calculate U2 =f(p1, phi1, dt+dt) and corresponding p2, phi2 and final error/ residual at the end of 2nd time step and so on....
Old   August 18, 2016, 08:31
Bruno Blais
Yup, That is exactly so.
OpenFOAM is a segregated solver, that is U, V, W, phi and P are solved segregated. This is why such a thing happen.
There are block coupled solvers in foam-extend, but those are still linear solver and don't implement a non-linear newton method or something like that.
If t0 =0:
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
