August 13, 2013, 09:08 |
Converting Pointwise volumes to OpenFOAM
tobyB
Rep Power: 12 |
Hello all
I have managed to sucessfully export some pointwise meshes to openFoam already by setting the solver, then changing boundary conditions and export->CAE with blocks selected. This worked fine. What didnt work was when I tried to use 'set volume conditions' using the same method as for boundary condtions but no extra files were produced in the directory. I am trying to simulate a case with 2 cubes side by side, one filled with cold gas, the other with a hot solid, then solving for heat transfer. I know the example is simple but if I could get the export working then I would move to more complex geometries. Any help on this matter would be appreciated edit: apologies forthis being in the wrong section Last edited by tobyB; August 13, 2013 at 09:11. Reason: Wrong section |
August 13, 2013, 09:58 |
Dennis Kingsley
Rep Power: 17 |
I do not believe that Pointwise's volume conditions are available for export to OpenFOAM, I use the OpenFOAM utilities like setField to perform this function.
August 13, 2013, 10:57 |
tobyB
Rep Power: 12 |
Ah, that would make sense. Do you know how I can get information on how to use setField then?
Thanks |
August 13, 2013, 11:04 |
Dennis Kingsley
Rep Power: 17 |
look at the AllRun script for the dam break tutorial.
[Commercial meshers] converting Fluent mesh to openfoam standard mesh | deepesh | OpenFOAM Meshing & Mesh Conversion | 31 | March 29, 2017 05:59 |
[Commercial meshers] Non-Orthogonal faces problem- Pointwise export to OpenFOAM | Milad06 | OpenFOAM Meshing & Mesh Conversion | 1 | February 11, 2014 12:03 |
ESI-OpenCFD Releases OpenFOAM v2.2.0 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 13 | March 30, 2013 16:52 |
[Commercial meshers] Native OpenFOAM interface in Pointwise | cnsidero | OpenFOAM Meshing & Mesh Conversion | 41 | May 20, 2012 18:30 |
Native OpenFOAM interface in Pointwise | Chris Sideroff | Main CFD Forum | 0 | January 16, 2009 12:37 |
