Converting Pointwise volumes to OpenFOAM
Old   August 13, 2013, 09:08
Default Converting Pointwise volumes to OpenFOAM
tobyB
tobyB is on a distinguished road
Hello all
I have managed to sucessfully export some pointwise meshes to openFoam already by setting the solver, then changing boundary conditions and export->CAE with blocks selected. This worked fine.
What didnt work was when I tried to use 'set volume conditions' using the same method as for boundary condtions but no extra files were produced in the directory.
I am trying to simulate a case with 2 cubes side by side, one filled with cold gas, the other with a hot solid, then solving for heat transfer. I know the example is simple but if I could get the export working then I would move to more complex geometries.
Any help on this matter would be appreciated
edit: apologies forthis being in the wrong section
tobyB is offline   Reply With Quote
Old   August 13, 2013, 09:58
Dennis Kingsley
dkingsley is on a distinguished road
I do not believe that Pointwise's volume conditions are available for export to OpenFOAM, I use the OpenFOAM utilities like setField to perform this function.
dkingsley is offline   Reply With Quote
Old   August 13, 2013, 10:57
tobyB
Ah, that would make sense. Do you know how I can get information on how to use setField then?
Thanks
Old   August 13, 2013, 11:04
Dennis Kingsley
look at the AllRun script for the dam break tutorial.
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
[Commercial meshers] Non-Orthogonal faces problem- Pointwise export to OpenFOAM Milad06 OpenFOAM Meshing & Mesh Conversion 1 February 11, 2014 12:03
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
[Commercial meshers] Native OpenFOAM interface in Pointwise cnsidero OpenFOAM Meshing & Mesh Conversion 41 May 20, 2012 18:30
Native OpenFOAM interface in Pointwise Chris Sideroff Main CFD Forum 0 January 16, 2009 12:37
