February 20, 2014, 07:20 |
Cooling tower: several aspects
Marcus Letzel
Dear Foamers,
my set-up is a cooling tower. The lowest some meters of the air within this tower act as a porous medium. This porous volume has a cylinder geometry. Let's say the characteristic vertical coordinates (height above ground) are
The porous volume acts as a flow conditioner/straightener insofar as u=v=0 within this volume, only w /= 0, i.e. only vertical motion is possible. Is it possible to realize the following strategy with OpenFOAM, and if so, how?
Best regards, Marcus |
February 22, 2014, 12:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Marcus,
In OpenFOAM, what you're looking for is the creation of a cell zone, not internal patches . As of OpenFOAM 2.2, there are several tutorials that exemplify how to use the fvOption named "explicitPorositySource", as indicated in the release notes for OpenFOAM 2.2.0: http://www.openfoam.org/version2.2.0/fvOptions.php You can find the tutorials that use this here: Code:
find $FOAM_TUTORIALS -name "fvOptions" | xargs grep explicitPorositySource Bruno PS: I erased the post you had at http://www.cfd-online.com/Forums/ope...nal-faces.html, since it was identical to this one and wasn't fully related to that other thread.
February 25, 2014, 11:29 |
Marcus Letzel
Dear Bruno,
thanks a lot for pointing me into this direction. Cell zones will certainly help to model the porosity effect. This even allows to model the effect of the flow conditioner/straightener by setting the horizontal resistance to a value some orders of magnitude larger than the vertical resistance. Great! So, the decelerating part of my problem should be fine. However, I do not see how this helps me to tackle the ascelerating part of my problem, namely to create buoyancy inside the tower. I would like to do so by prescribing a warmer temperature inside (fixed in time). Is it possible to achieve this by tweaking OpenFOAM using a cyclic patch, i.e. to place a thin pair of cyclic patches at the top of the porosity cell zone and prescribe warm temperature there? Or is there any other way to create buoyancy inside? Has anybody ever combined the two solvers porousSimpleFoam and buoyantBoussinesqSimpleFoam into one new solver? I only need the Forchheimer part of the porosity model. Cheers, Marcus P.S.: Thank you for cleaning up my post in the other thread, I agree it is more appropriate to treat my questions within the present thread. Last edited by letzel; February 25, 2014 at 11:35. Reason: clarification |
February 25, 2014, 17:45 |
Joachim Herb
Rep Power: 21 |
Using OpenFOAM 2.2.2 I can specify porousity with fvOptions and use the solver bouyantPimpleFoam so I guess you should be able to do the same with buoyantBoussinesqSimpleFoam
March 14, 2014, 12:12 |
Marcus Letzel
Thank you Joachim and Bruno for your suggestions which pointed me into the right direction.
For the accelerating part of the problem I am now using another fvOption to emulate the effect of warm water injection: Code:
warmWasserEinlass { type scalarExplicitSetValue; active true; selectionMode cellSet; cellSet warmWasserEinlassEbeneZellen; scalarExplicitSetValueCoeffs { volumeMode absolute; injectionRate { T 323; } } } I set the DarcyForchheimerCoeffs d to (0 0 0) and f to say (1000 1000 10). The decelerating effect in the vertical direction is fine, i.e. the third component of f, here 10, is out of question. However, the flow straightening effect (my target is: u=v=0 within the cellZone) is insufficient because the flow should be strictly vertical within the entire cellZone. Even if I increase the first two components of f, here 1000, to even larger values, there will always be a balance of forces and in effect the flow will not be 100% vertical. So, I am wondering whether there are better ways to achieve a truely vertical flow in OpenFOAM, i.e. to force u=v=0 but leave w unmodified. Question: is it possible to use fvOption vectorExplicitSetValue but specify only two of the three vector components? Or does swak4Foam offer such functionality? Best regards, Marcus |
March 15, 2014, 03:07 |
Bruno Santos
Rep Power: 128 |
Hi Marcus,
I'm not familiar enough with swak4Foam to know if there are any "fvOptions" features in it. But the "README" file inside the swak4Foam folder should indicate if it does and what it is. As for the flow being fully vertical: I don't have time to test this myself, but the suggestion I have is as follows:
Bruno
buoyancy, porous zone |
How to Modelling Cooling Tower using Porous Media | harkerz | FLUENT | 2 | June 6, 2017 08:31 |
Help me to simulate mixture model in cooling tower | harkerz | FLUENT | 0 | April 24, 2013 06:09 |
cooling tower | nocfdplease | Main CFD Forum | 0 | May 13, 2012 10:40 |
Cooling Tower | Roberto | FLUENT | 8 | July 22, 2009 03:16 |
Evaporation of droplets in cooling tower @cfx10-11 | Mauricio Labarca | CFX | 0 | March 28, 2008 20:02 |
