Problem with finite area method in parallel (foam-extend-4.0) |
May 3, 2017, 06:55 |
Andrea
Rep Power: 10 |
Hi all,
I would like to run finite area solvers in parallel. I copied both liquidFilmFoam and surfactantFoam tutorials, adding in the system folder the decomposeParDict from incompressible/simpleFoam/pitzDaily tutorial. After blockMesh and makeFaMesh, I've decompose the case using decomposePar without a hitch. Finally, I've tried to run the case in parallel typing "runParallel surfactantFoam 4 &", getting this error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0-4fad65ce7cac Exec : surfactantFoam -parallel Date : May 02 2017 Time : 13:03:33 Host : ManDybHig_clust PID : 5971 CtrlDict : "/stoc/andrea/OpenFOAM_EXT/andrea-4.0/tutorial/FAM/planTransport/system/controlDict" Case : /stoc/andrea/OpenFOAM_EXT/andrea-4.0/tutorial/FAM/planTransport nProcs : 4 Slaves : 3 ( ManDybHig_clust.5972 ManDybHig_clust.5973 ManDybHig_clust.5974 ) Pstream initialized with: nProcsSimpleSum : 0 commsType : nonBlocking SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 [0] [0] [0] --> FOAM FATAL ERROR: [0] otherProcNo:2 : illegal communicator -1650115904 Communicator should be within range 0..0 [0] [0] From function PstreamGlobals::checkCommunicator(const label, const label) [0] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [0] FOAM parallel run aborting [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] otherProcNo:0 : illegal communicator -1104586048 Communicator should be within range 0..0 [1] [1] From function PstreamGlobals::checkCommunicator(const label, const label) [1] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [1] FOAM parallel run aborting [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] otherProcNo:0 : illegal communicator -886773056 Communicator should be within range 0..0 [2] [2] From function PstreamGlobals::checkCommunicator(const label, const label) [2] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [2] FOAM parallel run aborting [2] [3] [3] [3] --> FOAM FATAL ERROR: [3] otherProcNo:2 : illegal communicator 1469405888 Communicator should be within range 0..0 [3] [3] From function PstreamGlobals::checkCommunicator(const label, const label) [3] in file db/IOstreams/Pstreams/PstreamGlobals.C at line 72. [3] FOAM parallel run aborting [3] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- I get the same error with all the finite-area-method tutorials. I haven't found any suggestion for this. Is the above procedure correct? I'm not able to figure out where this error came from . Thanks, Andrea Last edited by andlog; May 3, 2017 at 12:48. |
May 3, 2017, 12:47 |
Andrea
Rep Power: 10 |
This afternoon I've tried the same tutorials in parallel using foam-extend-3.2 and all successfully run.
Therefore, I guess it is an issue related to foam-extend-4.0. Andrea |
chtMultiRegionSimpleFoam: crash on parallel run | student666 | OpenFOAM Running, Solving & CFD | 3 | April 20, 2017 11:05 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
