September 17, 2014, 20:10 |
OF fails after "Create mesh for time = 0"
Bharat R Agrawal
I am using pisoFoam to run LES over an essentially 2D geometry extruded in third dimension with 128 cells. I am using periodic boundary conditions for the third dimension and total cell count is ~34 millions. I am using scotch decomposition for partitioning.
The solver fails right after "Create mesh for time = 0" with an error, corresponding error log attached as error1.txt. A similar set up ran with debug mode showed similar error stack which is attached as error2.txt. On looking through forums I came across a bug reported with title "0000879: OF crashes using cyclic BC with scotch decomposition" (http://www.openfoam.org/mantisbt/view.php?id=879). Since this was marked resolved and my error stack looks similar I reported another bug with title "0001386: OF fails after "Create mesh for time = 0" (http://www.openfoam.org/mantisbt/view.php?id=1386). However, it hasn't been assigned yet. So I am writing here to look for ideas to go around this problem. Thanks, Bharat |
[snappyHexMesh] snappyHexMesh & Mesh around a missile | sasanghomi | OpenFOAM Meshing & Mesh Conversion | 2 | October 15, 2014 19:54 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
[Netgen] Netgen mesh of a geometry with a cut fails | kontra | OpenFOAM Meshing & Mesh Conversion | 0 | November 28, 2013 09:46 |
[ICEM] Mirror Mesh | Delete duplicate mesh | pythag0ra5 | ANSYS Meshing & Geometry | 6 | November 19, 2013 07:35 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
