Multi subset mesh motion for OF 2.3
Old   February 16, 2015, 01:38
Default Multi subset mesh motion for OF 2.3
Christoph Gradl
ChristophGradl is on a distinguished road
Hello!
I tried to port the subset mesh motion of foam-extend 3.1 to OF 2.3, but it does not work in the right way. The motion solver table can not be found at runtime.
Maybe someone has already implement it in OF 2.3 and can share the source code with me.
Thanks!
Regards,
Christoph
ChristophGradl is offline   Reply With Quote
Old   April 30, 2015, 07:22
Hao Chen
hchen is on a distinguished road
Hi Christop:
Did you manage to do it?
Best regards
Hao
hchen is offline   Reply With Quote
Old   May 4, 2015, 01:06
Christoph Gradl
Hi Hao,
I am sorry, but I didn't! But with spending some time it should be feasible. I wrote my own class for mesh motion for my specific problem - was the simplest way.
If you have a solution, maybe you can post it here!
Best regards,
Christoph
Old   October 22, 2015, 07:52
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Dear Christoph,
Can you explain a bit how you did that in foam-extend 3.1?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   October 29, 2015, 14:27
Christoph Gradl
Hello!
I did not use OF extend, I used OF 2.3 after all.
Finally, I modified an existing class, because all basic classes for the mesh motion capabilities are includes in OF 2.3. I modified the class which is used for add and remove layers of a piston.
If you are interested in my work, I can share some details and if a found a simple case I can also send it to you.
Regards,
Christoph
Old   October 29, 2015, 15:27
Mojtaba.a's Avatar
Originally Posted by ChristophGradl View Post
Hello!
Regards,
Christoph
Well Thank you, I would be very grateful if you can share same details with me.
My Email address is: amiraslanpoor@gmail.com
With all the best.
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 10:08
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 13:22
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
