openFoam run functions, runApplication, getApplication
Like Tree12Likes
  • 8 Post By wyldckat
  • 2 Post By wyldckat
Old   February 22, 2015, 11:30
Default openFoam run functions, runApplication, getApplication
Hassan
luckycfd is on a distinguished road
Hello all,
I want to use my own solver 'interPhaseChangeFoam_0' in a case by its tutorial 'Allrun' script. The script is shown below:
 #!/bin/sh
 cd ${0%/*} || exit 1    # run from this directory
 # Source tutorial run functions
 . $WM_PROJECT_DIR/bin/tools/RunFunctions
 # copy bullet surface from resources folder
 cp $FOAM_TUTORIALS/resources/geometry/bullet.stl.gz constant/triSurface/
 # Generate the base block mesh
 runApplication blockMesh
 # Generate the snappy mesh
 runApplication snappyHexMesh -overwrite
 # Run the solver
 runApplication `getApplication`
For this reason, I edit the file system/controlDict of the case so the application is changed from interPhaseChangeFoam to interPhaseChangeFoam_0.
But after this, the script can,t access to my own solver then can not run. How can I configure this script or file system/controlDict to right accessing the new solver by keeping its original key words 'runApplication' and 'getApplication'?
Best regards,
Hassan
luckycfd is offline   Reply With Quote
Old   February 22, 2015, 12:00
Retired Super Moderator
Bruno Santos
Greetings Hassan,
No, no, no... don't call your solver that!
For better or for worse, the shell function "getApplication" was not designed to allow names with numbers and characters in them. It was designed with the naming convention used by the solvers and utilities in OpenFOAM, namely to use normal names, like "simpleFoam" and "rhoPimpleFoam" (I know, not very normal, but spaces are prohibited in C/C++ names for variables).
This to say that you should name your solver something like "interPhaseChangeFoamZero".
Best regards,
Bruno
Old   February 22, 2015, 12:42
Hassan
Hi
Thanks Bruno for your clear answer. Now, how can I discover openfoam conventions like this?
Old   February 22, 2015, 13:22
Bruno Santos
A bit by trial an error, as well as getting a feeling by how the OpenFOAM source code is... uhm... coded.
Then there's this page: http://www.openfoam.org/contrib/code-style.php
You can get there through this link path:
edit: The updated links are:
vortex_shedding and qutadah.r like this.
Old   October 19, 2015, 01:46
PicklER is on a distinguished road
Hi Bruno
Thank you for your answer. Is there a way to obtain the 0 (zero) that the solver returns when it is done executing? For example (in the shell script):
#!/bin/sh
application=`getApplication`
runApplication setFields
result = runApplication $application
echo $result
# ----------------------------------------------------------------- end-of-file
This does not work (novice at shell scripting). I want the variable result to be equal to 0 (for a default solver). The reason for this is that I want to run the solver multiple times with a for loop in the shell script and the condition to end the loop will be the value (int) returned by the solver.
Kind regards
PicklER is offline   Reply With Quote
Old   October 22, 2015, 16:29
Bruno Santos
Quick answer: Google:
bash script get error code
2nd hit: http://tldp.org/LDP/abs/html/exit-status.html
Try this:
result=$?
echo $result
vsammartano and betterglobe like this.
Old   October 22, 2015, 16:49
Talking
Hi Bruno
Thank you for your amswer. I found that solution this morning. Did not xpect it to be that simple. Will defintely improve my Google before I post a question.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
How to run OpenFoam using openMP. bravikanth OpenFOAM Running, Solving & CFD 12 June 20, 2016 10:11
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0 Jiricbeng OpenFOAM Running, Solving & CFD 15 May 21, 2014 03:52
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
