November 5, 2015, 07:45 |
#21 |
ok
Rep Power: 13 |
Dear Bruno,
I'm using your FSI library in foam-extend3.1, fsiFoam solver, in order to get the solution for 2d and 3d case of of the elastic cantilever attached to a square bluff body. I already get the solution for 2d case, now, I'm working for 3d case. I need to use extrude2dMesh utility in order to change from 2d to 3d. Is that possible? If yes, could you please send me steps how to apply that. Many thanks in advanced and regards. Maimouna |
November 8, 2015, 14:46 |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: http://www.cfd-online.com/Forums/ope...-not-work.html
November 9, 2015, 06:29 |
#23 | ||
ok
Rep Power: 13 |
Dear Bruno,
I tried what people posted in http://www.cfd-online.com/Forums/ope...-not-work.html. My extrude2DMeshDict in system directory is Quote:
Best regards |
November 15, 2015, 14:53 |
#24 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Sorry, I didn't have time to test and to take a better look at this the other day. The first problem is that the thread I mentioned is for OpenFOAM 2.2, which has a considerably different extrude2DMesh application from the one in foam-extend 3.1. Looks like extrude2dMesh is not what you are looking for. extrudeMesh does what you want:
But then I though a bit better and I have to ask: Why are you trying to complicate this, when you can simply modify the two "blockMeshDict" files and change the Z position values and increase the mesh refinement along that direction? Best regards, Bruno
November 19, 2015, 07:06 |
#25 |
ok
Rep Power: 13 |
Dear Bruno,
many thanks for your last post. I tried your both suggestion Code:
I had to first modify the file "blockMeshDict" and separate the "front" and "back" patches, now named "frontPlane" and "backPlane". I then modified the content to this: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object extrudeProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Where to get surface from: either from surface ('surface') or // from (flipped) patch of existing case ('patch') constructFrom patch; //surface; // If construct from (flipped) patch sourceCase "$FOAM_CASE"; sourcePatch frontPlane; // Flip surface normals before usage. flipNormals false; // If construct from surface //surface "movingWall.sMesh"; // Do front and back need to be merged? Usually only makes sense for 360 // degree wedges. mergeFaces false; //- Linear extrusion in point-normal direction extrudeModel linearNormal; nLayers 20; linearNormalCoeffs { thickness 1.0; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Code: blockMesh extrudeMesh But it didn't give the exact result I was hoping for. also, I didn't find what I hope. ExtrudeMesh utility give me this error Code:
owner@owner-HP-Pavilion-Sleekbook-15-PC:~/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/myCylinderCase-FsiLinear3dExtrude/fluid$ extrudeMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.1 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.1-f61aab88e799 Exec : extrudeMesh Date : Nov 19 2015 Time : 11:45:24 Host : owner-HP-Pavilion-Sleekbook-15-PC PID : 4044 CtrlDict : /home/owner/foam/foam-extend-3.1/etc/controlDict Case : /home/owner/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/myCylinderCase-FsiLinear3dExtrude/fluid nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Selecting extrudeModel linearNormal Extruding patch frontPlane on mesh "/home/owner/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/myCylinderCase-FsiLinear3dExtrude/fluid" Create polyMesh for time = 0 --> FOAM FATAL ERROR: Cannot find patch frontPlane in the source mesh. Valid patch names are 3 ( sides originalPatch otherSide ) From function extrudeMesh in file extrudeMesh.C at line 105. FOAM exiting owner@owner-HP-Pavilion-Sleekbook-15-PC:~/foam/owner-3.1/FluidStructureInteraction/run/fsiFoam/myCylinderCase-FsiLinear3dExtrude/fluid$ The second suggestion Code:
But then I though a bit better and I have to ask: Why are you trying to complicate this, when you can simply modify the two "blockMeshDict" files and change the Z position values and increase the mesh refinement along that direction? Kind regards Maimouna Last edited by wyldckat; November 22, 2015 at 15:08. Reason: repaired broken dictionary content |
November 22, 2015, 15:31 |
#26 | ||
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Build : 3.1-1dd681f6e943 Exec : extrudeMesh Date : Nov 22 2015 Time : 20:14:19 Host : machine PID : 4578 CtrlDict : /home/ofuser/foam/foam-extend-3.1/etc/controlDict Case : /home/ofuser/foam/ofuser-3.1/run/myCylinderCase-Fsi3d/fluid nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Selecting extrudeModel linearNormal Extruding patch frontPlane on mesh "/home/ofuser/foam/ofuser-3.1/run/myCylinderCase-Fsi3d/fluid" Create polyMesh for time = 0 Writing patch as surfaceMesh to "/home/ofuser/foam/ofuser-3.1/run/myCylinderCase-Fsi3d/fluid/frontPlane.sMesh" Extruding patch with : points : 9114 faces : 8850 normals[0] : (0 0 -1) Mesh bounding box : (0 0 -0.9) (19.5 12 0.1) with span : (19.5 12 1) Merge distance : 0.0001 Collapsing edges < 0.0001 ... End Quote:
The only reasons I see for it to no longer be able to move is possibly due to at least one of the following:
Bruno
November 28, 2015, 16:03 |
#27 |
ok
Rep Power: 13 |
Dear Bruno,
do you have any suggestion for fluid and solid properties should change in this case? I'm thinking about plate thickness of the solid part and omega (angle rad/s) in terms of helping plate to twist (in 2D the rod moves up and down only, in 3D it twist) that what I'm thinking. If you have any idea or source would help me in this case would be really appreciated. Kind regards Maimouna |
November 28, 2015, 18:57 |
#28 | ||
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
I haven't run the simulation, since it takes a while to run, but that has reminded me of something: in 2D, the front and back patches are of type "empty", which for solid displacement result in slip walls, i.e. it allows these patches to be distorted. But in 3D, you defined the file "solid/0/pointD" like this: Code:
boundaryField { plate { type calculated; value uniform (0 0 0); } plateFix { type fixedValue; value uniform (0 0 0); } frontPlane { type fixedValue; value uniform (0 0 0); } backPlane { type fixedValue; value uniform (0 0 0); } } Please try replacing the last two with this: Code:
frontPlane { type slip; } backPlane { type slip; } In addition, perhaps the same should be done for the other fields, at least for the velocity field "fluid/0/U". Keep in mind that you are simulating the distortion of a solid, not just the flow of a fluid. Therefore, you should keep in mind what exactly you are trying to simulate in 3D. Best regards, Bruno
December 9, 2015, 11:06 |
#29 |
ok
Rep Power: 13 |
Hi Bruno,
after waiting for long time to see the result, the case is working with the last post changes. That's a bit good news, but I'm still looking to see rod twist in 3D. The rod is moving up and down. What can I add to see the result that I expected? The only changes in rhyologyProperties file in solid/ constant directories Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object rheologyProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // planeStress no; //No for 3D, Yes for 2D rheology { type linearElastic; rho rho [1 -3 0 0 0 0 0] 7.82e3; //1000; //1; //0.1; E E [1 -1 -2 0 0 0 0] 2.0e10; //2.5e6; //5.6e6; //Young's modulus--> elasticity value nu nu [0 0 0 0 0 0 0] 0.265; //0.35; //0.4; //Poisson's ratio omega omega [0 0 0 0 0 0 0] 105; // rad/s thickness thickness [0 1 0 0 0 0 0] 0.1; } // ************************************************************************* // My regards Maimouna |
December 9, 2015, 18:02 |
#30 | |
Bruno Santos
Rep Power: 128 |
If you want the rod to twist, then think about how you would do that physically. In essence, for the rod to twist, either the flow cannot be symmetric, or you must have at least one more fixed point or edge or surface. You can use a piece of paper (in real life) to pretend it's the rod and then imagine the fluid flow going around each side of the paper, depending on how you are holding the paper. Please do keep in mind that you are trying to simulate something from the real world. You are not trying to develop a new high density molecule that is able to something completely new and non-existent in the real world. Therefore, you should be able to make real life experiments to check how stuff works, so that you can reproduce in a simulation! |
December 12, 2015, 10:09 |
#31 |
Wojciech Gołąbek
Rep Power: 12 |
Hi
I'm using fsiFOAM to solve similar issue and I would like to use parallel computations to accelerate it. How to modify the script Allrun and makeSerialLinks to run parallel computing? Best regards |
December 14, 2015, 06:45 |
#33 |
ok
Rep Power: 13 |
Dear Bruno,
following the presentation given in HTML Code:
http://docslide.us/engineering/a-first-order-conservation-law-formulation-for-fast-solid-dynamics-in-openfoam.html Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object rheologyProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // planeStress no; //No for 3D, Yes for 2D rheology { type linearElastic; rho rho [1 -3 0 0 0 0 0] 7.82e3; //1000; //1; //0.1; E E [1 -1 -2 0 0 0 0] 2.0e10; //2.5e6; //5.6e6; //Young's modulus--> elasticity value nu nu [0 0 0 0 0 0 0] 0.265; //0.35; //0.4; //Poisson's ratio omega omega [0 0 -1 0 0 0 0] 105; // angular velocity (rad/s) thickness thickness [0 1 0 0 0 0 0] 0.1; } // ************************************************************************* // Kind regards Maimouna |
December 29, 2015, 07:13 |
#34 |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Sorry, took me a while to get back to posting on the forum and to get to your question. Where should I start... OK, I'll summarize:
Bruno
January 1, 2016, 12:09 |
#35 | |
ok
Rep Power: 13 |
Merry Christmas and happy new year. The torsion occurs naturally due to forces from the fluid flow around the plate. I hope that could open your mind to help me with some ideas. Lots of thanks. Maimouna |
January 1, 2016, 13:27 |
#36 | |
Bruno Santos
Rep Power: 128 |
Hi Maimouna,
Merry Christmas and a Happy New Year as well! Quote:
Maybe I'm missing something from your previous descriptions, but so far all I can remember is that:
Best regards, Bruno
January 11, 2016, 10:41 |
#37 |
ok
Rep Power: 13 |
Dear Bruno,
in my previous case (3D case) I tried to increase the width of the thin plate (from 0.06m - 0.8m) in order to see its folded, but it gave me (core damped) error (log file attached). I got that idea from the paper HTML Code:
http://onlinelibrary.wiley.com/doi/10.1002/nme.3033/pdf However, in order to apply the same case which shown in the same paper (picture attached) what is the best way for generating mesh? Could 2D blockMesh help or shall generated using another generated meshes software? Any idea would help me is fully appreciated. My regards Maimouna |
January 13, 2016, 05:30 |
#38 |
Wojciech Gołąbek
Rep Power: 12 |
Hi Maimouna
I don't know how your mesh looks right now but based on my own problems with this type of simulation I would say that your time step could be too big or Volume change (one of quality parameter of your mesh) is too big. Best regards, Wojciech |
January 13, 2016, 06:09 |
#39 |
ok
Rep Power: 13 |
Dear Woj3x,
lots of thanks for your post. my blockMeshDict file for the fluid part in my case case is shown below Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1;//dimensions in meters --> conversion 1 vertices ( (0 0 0.1) //0 (4.5 0 0.1) //1 (5.5 0 0.1) //2 (9.5 0 0.1) //3 (13 0 0.1) //4 (19.5 0 0.1) //5 (19.5 2 0.1) //6 (19.5 5.5 0.1) //7 (19.5 5.6 0.1) //8 (19.5 6.4 0.1) //9 (19.5 6.5 0.1) //10 (19.5 10 0.1) //11 (19.5 12 0.1) //12 (13 12 0.1) //13 (9.5 12 0.1) //14 (5.5 12 0.1) //15 (4.5 12 0.1) //16 (0 12 0.1) //17 (0 10 0.1) //18 (0 6.5 0.1) //19 (0 5.5 0.1) //20 (0 2 0.1) //21 (4.5 10 0.1) //22 (5.5 10 0.1) //23 (9.5 10 0.1) //24 (13 10 0.1) //25 (4.5 6.5 0.1) //26 (5.5 6.5 0.1) //27 (9.5 6.5 0.1) //28 (13 6.5 0.1) //29 (5.5 6.4 0.1) //30 (9.5 6.4 0.1) //31 (13 6.4 0.1) //32 (5.5 5.6 0.1) //33 (9.5 5.6 0.1) //34 (13 5.6 0.1) //35 (4.5 5.5 0.1) //36 (5.5 5.5 0.1) //37 (9.5 5.5 0.1) //38 (13 5.5 0.1) //39 (4.5 2 0.1) //40 (5.5 2 0.1) //41 (9.5 2 0.1) //42 (13 2 0.1) //43 (0 0 0.5) //44 <== 0 (4.5 0 0.5) //45 <== 1 (5.5 0 0.5) //46 <== 2 (9.5 0 0.5) //47 <== 3 (13 0 0.5) //48 <== 4 (19.5 0 0.5) //49 <== 5 (19.5 2 0.5) //50 <== 6 (19.5 5.5 0.5) //51 <== 7 (19.5 5.6 0.5) //52 <== 8 (19.5 6.4 0.5) //53 <== 9 (19.5 6.5 0.5) //54 <== 10 (19.5 10 0.5) //55 <== 11 (19.5 12 0.5) //56 <== 12 (13 12 0.5) //57 <== 13 (9.5 12 0.5) //58 <== 14 (5.5 12 0.5) //59 <== 15 (4.5 12 0.5) //60 <== 16 (0 12 0.5) //61 <== 17 (0 10 0.5) //62 <== 18 (0 6.5 0.5) //63 <== 19 (0 5.5 0.5) //64 <== 20 (0 2 0.5) //65 <== 21 (4.5 10 0.5) //66 <== 22 (5.5 10 0.5) //67 <== 23 (9.5 10 0.5) //68 <== 24 (13 10 0.5) //69 <== 25 (4.5 6.5 0.5) //70 <== 26 (5.5 6.5 0.5) //71 <== 27 (9.5 6.5 0.5) //72 <== 28 (13 6.5 0.5) //73 <== 29 (5.5 6.4 0.5) //74 <== 30 (9.5 6.4 0.5) //75 <== 31 (13 6.4 0.5) //76 <== 32 (5.5 5.6 0.5) //77 <== 33 (9.5 5.6 0.5) //78 <== 34 (13 5.6 0.5) //79 <== 35 (4.5 5.5 0.5) //80 <== 36 (5.5 5.5 0.5) //81 <== 37 (9.5 5.5 0.5) //82 <== 38 (13 5.5 0.5) //83 <== 39 (4.5 2 0.5) //84 <== 40 (5.5 2 0.5) //85 <== 41 (9.5 2 0.5) //86 <== 42 (13 2 0.5) //87 <== 43 ); blocks ( hex (0 1 40 21 44 45 84 65) (30 15 10) simpleGrading (1 1 1) //1 hex (1 2 41 40 45 46 85 84) (15 15 10) simpleGrading (1 1 1) //2 hex (2 3 42 41 46 47 86 85) (30 15 10) simpleGrading (1 1 1) //3 hex (3 4 43 42 47 48 87 86) (35 15 10) simpleGrading (1 1 1) //4 hex (4 5 6 43 48 49 50 87) (50 15 10) simpleGrading (10 1 1) //5 hex (43 6 7 39 87 50 51 83) (50 8 10) simpleGrading (10 1 1) //6 hex (42 43 39 38 86 87 83 82) (35 8 10) simpleGrading (1 1 1) //7 hex (41 42 38 37 85 86 82 81) (30 8 10) simpleGrading (1 1 1) //8 hex (40 41 37 36 84 85 81 80) (15 8 10) simpleGrading (1 1 1) //9 hex (21 40 36 20 65 84 80 64) (30 8 10) simpleGrading (1 1 1) //10 hex (20 36 26 19 64 80 70 63) (30 2 10) simpleGrading (1 1 1) //11 hex (37 38 34 33 81 82 78 77) (30 2 10) simpleGrading (1 1 1) //12 hex (38 39 35 34 82 83 79 78) (35 2 10) simpleGrading (1 1 1) //13 hex (39 7 8 35 83 51 52 79) (50 2 10) simpleGrading (10 1 1) //14 hex (35 8 9 32 79 52 53 76) (50 2 10) simpleGrading (10 1 1) //15 hex (34 35 32 31 78 79 76 75) (35 2 10) simpleGrading (1 1 1) //16 hex (30 31 28 27 74 75 72 71) (30 2 10) simpleGrading (1 1 1) //17 hex (31 32 29 28 75 76 73 72) (35 2 10) simpleGrading (1 1 1) //18 hex (32 9 10 29 76 53 54 73) (50 2 10) simpleGrading (10 1 1) //19 hex (29 10 11 25 73 54 55 69) (50 15 10) simpleGrading (10 1 1) //20 hex (28 29 25 24 72 73 69 68) (35 15 10) simpleGrading (1 1 1) //21 hex (27 28 24 23 71 72 68 67) (30 15 10) simpleGrading (1 1 1) //22 hex (26 27 23 22 70 71 67 66) (15 15 10) simpleGrading (1 1 1) //23 hex (19 26 22 18 63 70 66 62) (30 15 10) simpleGrading (1 1 1) //24 hex (18 22 16 17 62 66 60 61) (30 13 10) simpleGrading (1 1 1) //25 hex (22 23 15 16 66 67 59 60) (15 13 10) simpleGrading (1 1 1) //26 hex (23 24 14 15 67 68 58 59) (30 13 10) simpleGrading (1 1 1) //27 hex (24 25 13 14 68 69 57 58) (35 13 10) simpleGrading (1 1 1) //28 hex (25 11 12 13 69 55 56 57) (50 13 10) simpleGrading (10 1 1) //29 ); edges ( ); patches ( patch inlet //left ( (17 61 62 18) (18 62 63 19) (19 63 64 20) (20 64 65 21) (21 65 44 0) ) patch outlet //right ( (12 56 55 11) (11 55 54 10) (10 54 53 9) (9 53 52 8) (8 52 51 7) (7 51 50 6) (6 50 49 5) ) patch top //up ( (17 61 60 16) (16 60 59 15) (15 59 58 14) (14 58 57 13) (13 57 56 12) ) patch bottom //down ( (0 44 45 1) (1 45 46 2) (2 46 47 3) (3 47 48 4) (4 48 49 5) ) patch cylinder //solid ( (26 70 71 27) (27 71 74 30) (33 77 81 37) (37 81 80 36) (36 80 70 26) ) patch plate //solid ( (30 74 75 31) (31 75 78 34) (34 78 77 33) ) patch frontPlane ( (0 1 40 21) //Block 1 front (1 2 41 40) //Block 2 front (2 3 42 41) //Block 3 front (3 4 43 42) //Block 4 front (4 5 6 43) //Block 5 front (43 6 7 39) //Block 6 front (42 43 39 38) //Block 7 front (41 42 38 37) //Block 8 front (40 41 37 36) //Block 9 front (21 40 36 20) //Block 10 front (20 36 26 19) //Block 11 front (37 38 34 33) //Block 12 front (38 39 35 34) //Block 13 front (39 7 8 35) //Block 14 front (35 8 9 32) //Block 15 front (34 35 32 31) //Block 16 front (30 31 28 27) //Block 17 front (31 32 29 28) //Block 18 front (32 9 10 29) //Block 19 front (29 10 11 25) //Block 20 front (28 29 25 24) //Block 21 front (27 28 24 23) //Block 22 front (26 27 23 22) //Block 23 front (19 26 22 18) //Block 24 front (18 22 16 17) //Block 25 front (22 23 15 16) //Block 26 front (23 24 14 15) //Block 27 front (24 25 13 14) //Block 28 front (25 11 12 13) //Block 29 front ) patch backPlane ( (44 45 84 65) //Block 1 back (45 46 85 84) //Block 2 back (46 47 86 85) //Block 3 back (47 48 87 86) //Block 4 back (48 49 50 87) //Block 5 back (87 50 51 83) //Block 6 back (86 87 83 82) //Block 7 back (85 86 82 81) //Block 8 back (84 85 81 80) //Block 9 back (65 84 80 64) //Block 10 back (64 80 70 63) //Block 11 back (81 82 78 77) //Block 12 back (82 83 79 78) //Block 13 back (83 51 52 79) //Block 14 back (79 52 53 76) //Block 15 back (78 79 76 75) //Block 16 back (74 75 72 71) //Block 17 back (75 76 73 72) //Block 18 back (76 53 54 73) //Block 19 back (73 54 55 69) //Block 20 back (72 73 69 68) //Block 21 back (71 72 68 67) //Block 22 back (70 71 67 66) //Block 23 back (63 70 66 62) //Block 24 back (62 66 60 61) //Block 25 back (66 67 59 60) //Block 26 back (67 68 58 59) //Block 27 back (68 69 57 58) //Block 28 back (69 55 56 57) //Block 29 back ) ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1;//dimensions in meters --> conversion 1 vertices ( (5.5 5.6 0.1) //0--19 (9.5 5.6 0.1) //1--20 (9.5 6.4 0.1) //2--22 (5.5 6.4 0.1) //3--21 (5.5 5.6 0.5) //4--45 (9.5 5.6 0.5) //5--46 (9.5 6.4 0.5) //6--48 (5.5 6.4 0.5) //7--47 ); blocks ( hex (0 1 2 3 4 5 6 7) (30 2 10) simpleGrading (1 1 1) //0 ); edges ( ); patches ( patch plateFix ( (3 7 4 0) ) patch plate ( (3 2 6 7) (6 2 1 5) (1 0 4 5) ) patch frontPlane ( (0 1 2 3) ) patch backPlane ( (7 6 5 4) ) ); mergePatchPairs ( ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application fsiFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1; //3; deltaT 1e-3; writeControl timeStep; writeInterval 20; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression compressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; //no; maxCo 0.2; functions ( pointHistory { type pointHistory; functionObjectLibs ( "libpointHistory.so" ); region solid; refHistoryPoint (7 6 0.25); // (7 6 0.05); } hronTurekReport { type hronTurekReport; functionObjectLibs ( "libhronTurekReport.so" ); } ); // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 3.0 | | \\ / A nd | Web: http://www.extend-project.de | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application stressFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 1; //3; deltaT 1e-3; writeControl timeStep; writeInterval 10; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; adjustTimeStep yes; //no; maxCo 0.2; // ************************************************************************* // Thanks alot. Maimouna |
January 13, 2016, 07:38 |
#40 |
Wojciech Gołąbek
Rep Power: 12 |
Hi Maimouna
Could you tell me what parameters of liquid (transportPtoperties) and solid (rheologyProperties) did you use in this simulation? Thank you in advance! From picture which you attached in your last post I see that you have really big volume change between blocks. You need to use simpleGrading (http://cfd.direct/openfoam/user-guid...#x25-1420005.3 5.3.1.3-5.3.1.4) to make smooth transition between them. Like in attached picture. About time step it's like Bruno told before. You need to control courant number (log.fsiFoam). If it's is too big (>1) you need to reduce your time step. Best regards, Wojciech |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
