multiRegionHeater tutorial visualization problem
Like Tree2Likes
  • 2 Post By Ahmed Khattab
Old   August 21, 2010, 11:47
Default multiRegionHeater tutorial visualization problem
Paulo Bufacchi
Bufacchi is on a distinguished road
Hi all,
I'm running OpenFOAM 1.7.x on Suse 11.3 64 bit platform.
I can run multiRegionHeater tutorial without any problem. I checked the log files and everything seems ok.
My problem starts when I run paraFoam. I can see U (velocity) and T (temperature) on a slice of the box for time = 0, but for times equal to 50, 100, 150 and 200 I can't see anything (the slice turns white and on the display menu, U and T are no longer there).
After having the problem, I used git to get the most recent changes to 1.7.x version and recompiled paraView just in case. The problem continues.
Suse 11.3 comes with gcc version 4.5.0.
Can someone please explain what should be the problem?
Thanks,
Paulo
Bufacchi is offline   Reply With Quote
Old   August 22, 2010, 15:30
Paulo Bufacchi
Well, in fact it is not a problem.
When I call paraFoam from within cht case, for some reason it opens only time 0 and when you try to access the other times, it doesn't show the data.
But when you open the .OpenFOAM files from within paraView, you see the data there.
Thanks,
Paulo
Old   May 16, 2012, 03:29
Ahmed Khattab's Avatar
ahmed
Ahmed Khattab is on a distinguished road
But when you open the .OpenFOAM files from wiget instead thin paraView, you see the data there.
Thanks,
Paulo
Hi every body. two years after your post and reply i faced same problem and it helped me solving it. i only have a small clarification
from tool bar choose file the open, from directory of the case choose all files with extension .openFoam (bottomair.OpenFoam, heatre.Openfoam,....etc). and will work properly.
thaks.
andbe and mizzou like this.
Ahmed Khattab is offline   Reply With Quote
Old   September 18, 2015, 09:20
Anders Berg
andbe is on a distinguished road
Thanks Ahmed,
your reply helped me some years after. =)
andbe is offline   Reply With Quote
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 05:34
newbie problem with cavity tutorial miki OpenFOAM Running, Solving & CFD 8 September 2, 2012 15:22
mpi problem with tutorial bed2 piterw82 OpenFOAM 9 June 23, 2010 14:59
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure shangzung OpenFOAM 0 November 1, 2009 13:07
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
