multiRegionHeater tutorial visualization problem |
August 21, 2010, 11:47 |
Paulo Bufacchi
I'm running OpenFOAM 1.7.x on Suse 11.3 64 bit platform. I can run multiRegionHeater tutorial without any problem. I checked the log files and everything seems ok. My problem starts when I run paraFoam. I can see U (velocity) and T (temperature) on a slice of the box for time = 0, but for times equal to 50, 100, 150 and 200 I can't see anything (the slice turns white and on the display menu, U and T are no longer there). After having the problem, I used git to get the most recent changes to 1.7.x version and recompiled paraView just in case. The problem continues. Suse 11.3 comes with gcc version 4.5.0. Can someone please explain what should be the problem? Thanks, Paulo |
August 22, 2010, 15:30 |
Paulo Bufacchi
Well, in fact it is not a problem.
When I call paraFoam from within cht case, for some reason it opens only time 0 and when you try to access the other times, it doesn't show the data. But when you open the .OpenFOAM files from within paraView, you see the data there. Thanks, Paulo |
May 16, 2012, 03:29 |
#3 | |
from tool bar choose file the open, from directory of the case choose all files with extension .openFoam (bottomair.OpenFoam, heatre.Openfoam,....etc). and will work properly. thaks. |
September 18, 2015, 09:20 |
Anders Berg
Thanks Ahmed,
your reply helped me some years after. =) |
Problem on Fluent Tutorial: Horizontal Film Boilig | Feng | FLUENT | 2 | April 13, 2013 05:34 |
newbie problem with cavity tutorial | miki | OpenFOAM Running, Solving & CFD | 8 | September 2, 2012 15:22 |
mpi problem with tutorial bed2 | piterw82 | OpenFOAM | 9 | June 23, 2010 14:59 |
Tutorial problem: "rhopSonicFoam - shockTube" with high pressure | shangzung | OpenFOAM | 0 | November 1, 2009 13:07 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
