backward Step with heat transfer - Problems on finer mesh |
November 14, 2015, 04:12 |
Rep Power: 10 |
Hi all,
I am simulating a backward facing step with heat transfer at the lower wall after the step using Nusselt-number as benchmark. With two relatively coarse meshes I obtain results close to experimental data. Using a third mesh which is heavily refined to the walls I get bad results overestimating Nusselt-number especially in the region of reattaching flow. I think it could be a problem of the near-wall-treatment in kOmegaSST-model I am using, since for Mesh 3 yPlus seriously drops below 1. BUT I thought using nutLowReWallFunction & kLowReWallFunction (+omegaWallFunction + alphatJayatillekeWallFunction) OF would automatically switch to LowRe-mode when the mesh get's to fine at the wall? Is that not implemented in OF? |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
how can I get the net heat transfer rate in every time step? | hotboy | FLUENT | 0 | October 22, 2015 07:52 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
heat transfer problems of a heat sink | tina | FLUENT | 2 | August 13, 2008 06:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
