backward Step with heat transfer - Problems on finer mesh |
November 14, 2015, 04:12 |
Rep Power: 11 |
I am simulating a backward facing step with heat transfer at the lower wall after the step using Nusselt-number as benchmark. With two relatively coarse meshes I obtain results close to experimental data. Using a third mesh which is heavily refined to the walls I get bad results overestimating Nusselt-number especially in the region of reattaching flow. I think it could be a problem of the near-wall-treatment in kOmegaSST-model I am using, since for Mesh 3 yPlus seriously drops below 1. BUT I thought using nutLowReWallFunction & kLowReWallFunction (+omegaWallFunction + alphatJayatillekeWallFunction) OF would automatically switch to LowRe-mode when the mesh get's to fine at the wall? Is that not implemented in OF? |
November 14, 2015, 05:03 |
some more specifics
Rep Power: 11 |
solver: buoyantBoussinesqSimpleFoam
geometry yPlus-values with N3 being the finest grid Mesh criteria |
November 14, 2015, 05:04 |
Additional question - Aspect ratio
Rep Power: 11 |
Is OpenFOAM sensitive to aspect ratio?
I learned it is with a limiting value of five but then I read in some sources that it isn't as long as checkMesh doesn't fail. |
November 14, 2015, 11:58 |
anonymous
Rep Power: 12 |
I am not quite sure, but I think that the current implementation of kOmegaSST is based on a High-Re implementation. I propose you to use this komega model instead
https://www.google.fr/url?sa=t&sourc...wr89UzCCo2wesA Or try using kOmegaSSTSAS which seems to be low-re Be careful always with the boundary conditions and wall functions with the different turbulence models in OpenFOAM. If you want to fully resolve the boundary layer try not using wall functions and see if it works better |
November 14, 2015, 15:43 |
Rep Power: 11 |
Thank you so much for this advice.
But from my understanding it is a "pure" LowRe-model thus always simulating the near wall region, no matter which yPlus-value present. In Fluent there is a scalable wall function which uses wall function if yPlus is big enough and switches to LowRe (simulation) if yPlus is below 1. Which is quite useful for "grid independent" solutions. Is something like this implemented? |
November 14, 2015, 15:50 |
#6 | |
anonymous
Rep Power: 12 |
That's why I proposed you to use the k-w-SST model in the link of my last post. It has de extra fluent terms and it can operate at low and high-re mode |
November 15, 2015, 09:16 |
Joachim Herb
Rep Power: 21 |
Perhaps this helps:
http://www.cfd-online.com/Forums/ope...ng-fluent.html |
November 15, 2015, 14:19 |
#8 | |
Rep Power: 11 |
Ok, so I used the low Re-model but it still gives the same results.
I used the following boundary conditions alphat: fixedValue 1e-12; nut: fixedValue 1e-12; k: fixedValue 1e-12; omega: omegaWallFunction; as recommended in the mentioned thread http://www.cfd-online.com/Forums/ope...ng-fluent.html Quote:
Then I would put omega to a near zero value as well? This makes the results even worse, so does anybody has an idea what could cause those problems, if the wall functions are not the matter? I uploaded an example of the calculations using the finest mesh here (including latest time step result): https://owncloud.tu-berlin.de/public...fe3a71201fbfa5 Last edited by hcl734; November 15, 2015 at 15:29. |
November 15, 2015, 15:36 |
Results for kOmegaSST_lowRe
Rep Power: 11 |
Using only omegaWallFunction
Using no wall function at all |
November 15, 2015, 16:48 |
Joachim Herb
Rep Power: 21 |
You also might find these threads helpful:
http://www.cfd-online.com/Forums/ope...estigated.html http://www.cfd-online.com/Forums/ope...ons-2-3-a.html |
November 16, 2015, 11:40 |
#11 |
Rep Power: 11 |
First of all thank you for your suggestions.
What I got from the threads you pointed me to is: kOmegaSST_lowRe with omegaWallFunction or without wall functions at all using Wilcox BC for omega I did both and the results still deteriorate with increasing mesh density, since I am not using wall functions here I assume it is a general mesh problem. Or we simply shouldn't use kOmegaSST for yPlus lower 1. Could you answer the question for me how sensitive OF is to mesh parameters? Since I got quite high aspect ratios and I am not sure whether this could be the main problem. checkMesh tells everything is ok and I imported the meshes from Ansys where they work just fine. |
problems after decomposing for running | alessio.nz | OpenFOAM | 7 | March 5, 2021 04:49 |
how can I get the net heat transfer rate in every time step? | hotboy | FLUENT | 0 | October 22, 2015 07:52 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
heat transfer problems of a heat sink | tina | FLUENT | 2 | August 13, 2008 06:11 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
