So close!
Old   March 11, 2016, 10:58
Default So close!
Alpha Beta
xoitx is on a distinguished road
Everything goes Fine and then this!
While running interDymFoam for sloshing tank 3d tutorial with cylinder tank and Boolean cut inside(Baffle :O)
--> FOAM FATAL IO ERROR:
Unable to set reference cell for field p
Reference point pRefPoint (0 0 0.15) found on 0 domains (should be one)
file: /home/bryce/openfoam30/tutorials/multiphase/interDyMFoam/ras/sloshingTank3D/system/fvSolution.PIMPLE from line 101 to line 107.
From function void Foam::setRefCell
const volScalarField&,
const dictionary&,
label& scalar&,
bool
in file cfdTools/general/findRefCell/findRefCell.C at line 109.
FOAM exiting
I used Salome for meshing and grouped surface geometries as 'walls'. I checked in parafoam (for the 0 timestamp) and I could see the water only at surface contact.. basically the entire mesh is only surface and not volume.. idk why. But when I switch from wireframe to volume I can see the water(blurry but still present)
The above error seems to be associated with setFields though.. any ideas?
xoitx is offline   Reply With Quote
Old   March 11, 2016, 15:38
BlnPhoenix is on a distinguished road
you're reference point for p seems to not be within the domain. Check if the point (0 0 0.15) is acutally in your domain. You can do that with parafoam and the streamlines tool ( the white cross marks any point, use these coordinates) for a reference point within your actual domain. Use this new reference point in the fvsolution file at the spot where u define the reference pressure point.
Give it a try.
BlnPhoenix is offline   Reply With Quote
[snappyHexMesh] crash sHM H25E OpenFOAM Meshing & Mesh Conversion 11 November 10, 2014 11:27
[GAMBIT] Close Gambit L3munoz ANSYS Meshing & Geometry 0 September 18, 2010 06:39
Close Domain - Engine Valve Alessio CFX 5 January 22, 2010 03:34
Mesh distortion close to cylind wall-GAMBIT 2.2.30 Mirek FLUENT 1 April 15, 2006 17:22
Canvas window does not close oduor CFX 5 June 12, 2002 21:53
