November 6, 2016, 06:38 |
simpleFoam - setting the pref value
Giles Richardson
Rep Power: 13 |
I have been running simpleFoam for flow analysis over a car and initially set pref = 101325 (in the fvSolution file) which was giving quite large forces when integrating the surface pressure over a car body.
I then changed pref=0 and re-ran the same case, giving significantly lower force values (and more realistic CL & CD), when integrating the surface pressure on vehicle. Think it maybe be related to the surface pressure integration method in Paraview. Last edited by ufocfd; November 6, 2016 at 14:55. |
November 9, 2016, 13:34 |
Mahdi Hosseinali
Rep Power: 18 |
When you're solving incompressible flow the absolute pressure is not important, it's just the gradient (even when integrating an immersed surface such as a car body). If your solutions are correct velocity profiles should be reasonable.
prefcell/prefvalue, simplefoam |
SimpleFoam setting with total pressure at inlet | dmaz | OpenFOAM Running, Solving & CFD | 2 | June 24, 2016 10:17 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
