MixedSmagorinsky parallel mode blows up with libOpenFOAMso error
Old   March 5, 2009, 18:20
Default Hi All I am not able to run
kumar
kumar2 is on a distinguished road
Hi All
I am not able to run channelOodles with the mixedSmagorinsky in parallel mode , looks like a libOpenFOAM.so error. BUT this configuration works well on SINGLE PROCESSOR.
The error is pasted below:
/////////////// ERROR ///////////////
[2] #0 [7] [0] #0 [1] #0 Foam::error::printStack(Foam:stream&)[3] #0 #0 [8] #0 Foam::error::printStack(Foam:stream&)[9] #0 Foam::error::printStack(Foam:stream&)[10] #0 Foam::error::printStack(Foam:stream&)Foam::error::printStack(Foam:stream&)Foam::error::printStack(Foam:stream&)Foam::error::printStack(Foam:stream&)Foam::error::printStack(Foam:stream&) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[2] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[8] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[9] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[0] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[1] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[3] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[7] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so"
[10] #1 Foam::sigFpe::sigFpeHandler(int) in "/datadir/rajagopa/OpenFOAM/OpenFO
///////////// END of ERROR /////////////
Thanks a lot
kumar
kumar2 is offline   Reply With Quote
Old   March 10, 2009, 00:31
Default Hi All, Any comments on why
kumar
Hi All,
Any comments on why mixedSmagorinsky model does not work in parallel ?
Old   April 5, 2014, 04:09
vut
vut is on a distinguished road
Dear Kuma2,
I would like to use mixedSmagorinsky model. However, I got a trouble with fvSchemes and fvSolution.
Would you like to share these files?
Thanks in advance,
vut
vut is offline   Reply With Quote
Parallel Fluent Error in Batch Mode Justin FLUENT 3 November 28, 2016 10:50
A UDF Problem in Parallel Mode Jun FLUENT 1 October 26, 2011 12:49
Getting error while running on parallel Mode velan OpenFOAM Running, Solving & CFD 8 May 10, 2009 03:26
to do a run in parallel mode with star_hpc massimo Siemens 4 January 30, 2003 08:33
How to run his phoenics in parallel mode? Bryan Lam Phoenics 3 December 19, 2001 09:43
