February 10, 2014, 13:23 |
Problem with running mixedSmagorinsky sgs
Petteri
Rep Power: 12 |
I'm comparing a couple of sgs models for turbulent pipe flow and so far I have been able to run Smagorinsky and oneEqEddy properly. For my last sgs model I would like to run mixedSmagorinsky but my fvschemes produce a long error:
--> FOAM FATAL IO ERROR: keyword div((dev((((surfaceSum((magSf*interpolate(sqr(U))) )|surfaceSum(magSf))-sqr((surfaceSum((magSf*interpolate(U)))|surfaceSum (magSf))))+(((0.666667)*((0.5*((surfaceSum((magSf* interpolate(magSqr(U))))|surfaceSum(magSf))-magSqr((surfaceSum((magSf*interpolate(U)))|surface Sum(magSf)))))+((((2*ck)|ce)*sqr(delta))*magSqr(de v(symm(grad(U)))))))-(nuSgs*twoSymm(grad(U))))))+(-nuEff*dev(twoSymm(grad(U)))))) is undefined in dictionary "/home/ubuntu/OpenFOAM/ubuntu-2.2.2/run/Kandi/putki/system/fvSchemes.divSchemes" my divschemes: divSchemes { default none; div(phi,U) Gauss linear; div((nuEff*dev(T(grad(U))))) Gauss linear; div((nu*dev(T(grad(U))))) Gauss linear; div((grad(U)&U)) Gauss linear; div(phi,k) Gauss limitedLinear 1; //* div(phi,B) Gauss limitedLinear 1; //* div(B) Gauss linear; //* } |
April 5, 2014, 03:53 |
Rep Power: 12 |
Dear hamsteri15,
I had the same error running mixed Smagorinsky model. Have you got the solution? Regards, vut |
April 5, 2014, 10:57 |
Eric Robertson
Rep Power: 14 |
The code is just telling you that there is a term hanging around that you have not told it how to discretize.
As a remedy, I would just place Gauss linear in the default category. In other words, instead of: default none; Place: default Gauss linear; That will discretize this remaining term. Now, as to what that term means- I do not know, because I do not know much about the implementation. |
April 5, 2014, 13:11 |
Rep Power: 12 |
I tried almost the same way: paste these formula and use Gauss linear.
Thanks anyway. It seems clearer now for fvScheme for me Nice weekend, vut |
Parallel running of 3D multiphase turbulence model (unknown problem!!) | MOHAMMAD67 | OpenFOAM Running, Solving & CFD | 7 | November 23, 2015 10:53 |
Problem while running in Highperformance computing environment | Phanipavan | STAR-CD | 1 | September 11, 2013 06:42 |
running FLUENT on cluster problem | cth_yao | FLUENT | 2 | December 2, 2011 06:05 |
problem with running in parallel | dhruv | OpenFOAM | 3 | November 25, 2011 05:06 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 07:52 |
