BC s in OpenFOAM
Old   September 3, 2008, 01:02
Default Hi everybody, I am new to Ope
Ameya Durve
ameya is on a distinguished road
Hi everybody,
I am new to OpenFOAM. Currently I am using OpenFOAM-1.5 Can you please tell me various boundary conditions available for inlet and outlet in OpenFOAM. I went through the user's guide but found it wasnt comprehenssive enough.
ameya is offline   Reply With Quote
Old   September 12, 2008, 15:12
Default fixedValue, zeroGradient are c
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
fixedValue, zeroGradient are commonly used for pressure, velocity, etc...
louisgag is offline   Reply With Quote
Old   September 16, 2008, 13:00
Default Hi Louis Thanks a lot. But
Ameya Durve
Hi Louis
Thanks a lot.
But what i actually wanted to know was whether we can define boundary conditions like velocity inlet or mass flow inlet or outflow, interior face etc. in OpenFOAM as we define in fluent
Old   September 16, 2008, 14:23
Default Hi Ameya, Yes you can speci
louisgag's Avatar
Louis Gagnon
Hi Ameya,
Yes you can specify inlet velocity. I believe you can also specify mass flow but I haven't tried that.
To specify inlet/outlet velocity you need to edit the files located in the "0" directory of the case you intend to run. You might wanna look at the tutorials, you will clearly see how to do it. I think the simpleFoam/pitzdaily tutorial has inlet and outlet velocity ("U") and pressure ("p") conditions defined. That would give you something to start with.
-Louis
Is GUI there for OpenFoam navaladi OpenFOAM 4 September 11, 2023 13:35
OpenFoam vs CFX5 mass balance in OpenFoam tangd OpenFOAM Running, Solving & CFD 33 May 23, 2010 16:36
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 martapajon OpenFOAM Meshing & Mesh Conversion 7 January 21, 2008 12:52
OpenFOAM users in Munich OpenFOAM benutzer in M%c3%bcnchen jaswi OpenFOAM 0 August 3, 2007 13:11
A new Howto on the OpenFOAM Wiki Compiling OpenFOAM under Unix mbeaudoin OpenFOAM Installation 2 April 28, 2006 08:54
