InterFoam and Channel Flow
Old   September 8, 2008, 18:03
Default I'm attempting to adapt the in
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
I'm attempting to adapt the interFoam solver to incorporate cyclic boundary conditions. I have had a look at the ChannelOodles solver and added several files (mainly the createGrad.H and writeGradP.H). The solver was able to compile and I have run the damBreak case with no problems, receiving similar result to the interFoam solver. However, when I apply cyclic BC's to another case, then there are problems. I must choose a ridiculously small courant number (1e-5) to even have continuity converge and even with that the pressure gradient still diverges. I will attach the solver and my case to see if anyone can help. Please take a look at it, see if there are any issues and maybe make some comments.
Thanks for any help that can be given. Also, I will be sure to share any knowledge gained with the community.
Dan
chegdan is offline   Reply With Quote
Old   September 9, 2008, 01:13
Default I took a quick look at your ca
vof_user
asaha is on a distinguished road
I took a quick look at your case file, may be some thing is missing in your pd file and see if reducing the deltaT further has any effect on the solution.
asaha is offline   Reply With Quote
InterFoam and Channel Flow chegdan OpenFOAM Running, Solving & CFD 2 December 14, 2011 10:26
maintain a constant flow rate in channel flow ? Lewis Main CFD Forum 2 September 28, 2010 11:35
InterFoam with vacuum in the flow domain possible hsieh OpenFOAM Running, Solving & CFD 0 May 1, 2008 10:02
Outlet boundary condition in channel flow solving with interFoam liuzhw OpenFOAM Running, Solving & CFD 0 November 29, 2005 21:07
