Ramjet Simulation
Old   September 8, 2008, 08:40
Default Hi, I am newbie to OpenFOAM,
Velan
velan is on a distinguished road
I am newbie to OpenFOAM, got started a week before. I started a ramjet simulation with M=2. Everything goes fine when i used the outlet as supersonic bc's(extrapolated). But when i applied Exit back pressure, the simulation starts blowing up. I am using standard RNG k-epsilon model. I am using sonicTurbFoam. Please help me to sort it out.
- Velan
velan is offline   Reply With Quote
Old   September 9, 2008, 00:21
Default With or without combustion ??
KaLee_Kun
kaleekun is on a distinguished road
kaleekun is offline   Reply With Quote
Old   September 9, 2008, 01:10
Default Its without combustion. We are
Velan
Its without combustion. We are simulating from forebody to cowl portion(which ends before combustion starts). So in the vicinity of cowl, i am getting cowl shock and it reflects(where i am getting separation bubble).
I ran the different case using openFOAM.
* Fully supersonic flow (Extrapolation at exit)
* Fully subsonic flow
* Restarted the simulation with Fully developed supersonic flow and applied exit pressure condition at the exit, but Normal shock was not formed.
So my problem is, i need to get a weak normal shock inside the cowl by applying exit pressure condition. Can you please suggest me how can i do it. If you have any idea please share with me.
- Velan
Old   September 9, 2008, 02:08
Default Hello Velan, In my experience
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hello Velan,
In my experience, it is very hard to find the right value of the backpressure for a certain position of the normal shock (see for example lambda shockwave), but it will always be a normal shock wave somewhere in your domain (or a strong oblique one). Even if you want to avoid the formation of a normal shock wave, it is impossible if you apply such a boundary condition, because you block one of the 5 outgoing characteristics which gives you a subsonic type of flow.
So my suggestion is to look closely, maybe you have a too low backpressure and your normal shockwave is exactly at the outlet, which means you have to increase a little its value.
I hope this is helpful,
Dragos
dmoroian is offline   Reply With Quote
two dimensional supersonic ramjet inlet model Alex FLUENT 1 November 17, 2017 11:45
ramjet inlet AE FLUENT 4 February 5, 2004 10:35
Inlet diffuser of ramjet Mohammad Kermani Main CFD Forum 25 December 29, 2000 18:46
