problem with boundary layer
Like Tree1Likes
  • 1 Post By gonpe
Old   April 17, 2012, 11:36
Default problem with boundary layer
usefkeyghobadi's Avatar
Youse Keyghobadi
usefkeyghobadi is on a distinguished road
Hello Foamer’s
I want to simulate Boundary Layer in Newtonian and viscoelastic Fluid on 2-D flat plate with openFoam 1.5 dev
My geometry is 2D flat plate
Width: 0.5 meter
Long: 5 meter
Uniform velocity: 1m/s
Velocity BC’s
Uperwall
Type fixedvalue;
Value uniform (1 0 0);
Lowerwall
Type fixedvalue;
Value uniform (0 0 0);
Inlet
Type fixedvalue
Outlet
Type zeroGradient;
Pressure BS’s
Uperwall
Type zeroGradient;
Lowerwall
Type zeroGradient;
Inlet
Type zeroGradient;
Outlet
Type fixedValue;
Value uniform 0;
I set zeroGradient boundary condition velocity for uperwall but got the similar result,
After simulation we have velocity profile as below:
According to boundary layer theory in anywhere velocity must lower or equal from uniform velocity
We used icoFoam and ViscoelasticFluidFoam(Giesekus Model) but in the both in some point velocity more than uniform velocity.
Please help me
regards
usefkeyghobadi is offline   Reply With Quote
Old   April 18, 2012, 16:10
Goncalo Pedro
gonpe is on a distinguished road
Hi
Mass flow must be maintained. If you are setting a uniform inflow and also constraining the top boundary to a certain velocity, then it is normal to expect a higher vel somewhere in your domain.
If you use a symmetryplane, this is alleviated, but could take a while/distance to stabilize.
usefkeyghobadi likes this.
gonpe is offline   Reply With Quote
Old   April 18, 2012, 19:59
Youse Keyghobadi
Hi
Thanks Gonpe
is The boundary conditions like the atmosphere there? For velocity and pressure to flow out and nowhere hasn't more velocity than uniform flow velocity
Thanks
Old   April 21, 2012, 15:50
Saba Saeb
saba_saeb is on a distinguished road
Originally Posted by usefkeyghobadi View Post
Hi
Thanks Gonpe
Thanks
According to "Gnope", the mass conservation equation, so called, continuity equation should be satisfied during the simulation. So the mass flow rate ( V*A ) through any arbitrary surface in any point of the channel should be same (consider that the area of any cross section is same according to the definition of your problem). In some points, the middle of the channel for instance, due to viscosity effects, fluid velocity next to the walls would be decreased, so fluid moves faster at the center to somehow compensate the velocity deficiency and fulfill the continuity equation. So it seems reasonable and logical if the fluid velocity in some points, gets bigger than the initial velocity that you have set so far.
cheers
Saba
saba_saeb is offline   Reply With Quote
Old   April 23, 2012, 10:25
Goncalo Pedro
Sorry for the late reply. Saba has re-iterated my earlier point ... thanks.
Just a last point. If you place a symmetry condition at the top of the domain, this will allow the speed to fluctuate along the top boundary.
Of course, this turns the problem into one of bounded channel flow. In this case, the speed should be highest at the upper boundary.
Goncalo
GAMBIT meshing problem for boundary layer Falah FLUENT 2 November 30, 2020 14:16
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
To thin boundary layer? Luk CFX 3 February 27, 2009 03:22
problem with boundary layer Bharath Main CFD Forum 1 July 11, 2008 09:06
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
