April 17, 2012, 11:36 |
problem with boundary layer
Youse Keyghobadi
Hello Foamer’s
I want to simulate Boundary Layer in Newtonian and viscoelastic Fluid on 2-D flat plate with openFoam 1.5 dev My geometry is 2D flat plate Width: 0.5 meter Long: 5 meter Uniform velocity: 1m/s Velocity BC’s Uperwall Type fixedvalue; Value uniform (1 0 0); Lowerwall Type fixedvalue; Value uniform (0 0 0); Inlet Type fixedvalue Value uniform (1 0 0); Outlet Type zeroGradient; Pressure BS’s Uperwall Type zeroGradient; Lowerwall Type zeroGradient; Inlet Type zeroGradient; Outlet Type fixedValue; Value uniform 0; I set zeroGradient boundary condition velocity for uperwall but got the similar result, After simulation we have velocity profile as below: According to boundary layer theory in anywhere velocity must lower or equal from uniform velocity We used icoFoam and ViscoelasticFluidFoam(Giesekus Model) but in the both in some point velocity more than uniform velocity. regards |
April 18, 2012, 16:10 |
Goncalo Pedro
Hi
Mass flow must be maintained. If you are setting a uniform inflow and also constraining the top boundary to a certain velocity, then it is normal to expect a higher vel somewhere in your domain. If you use a symmetryplane, this is alleviated, but could take a while/distance to stabilize. |
April 18, 2012, 19:59 |
Youse Keyghobadi
Hi
Thanks Gonpe is The boundary conditions like the atmosphere there? For velocity and pressure to flow out and nowhere hasn't more velocity than uniform flow velocity Thanks |
April 21, 2012, 15:50 |
#4 | |
Saba Saeb
cheers Saba |
April 23, 2012, 10:25 |
Goncalo Pedro
Sorry for the late reply. Saba has re-iterated my earlier point ... thanks.
Just a last point. If you place a symmetry condition at the top of the domain, this will allow the speed to fluctuate along the top boundary. Of course, this turns the problem into one of bounded channel flow. In this case, the speed should be highest at the upper boundary. Goncalo |
GAMBIT meshing problem for boundary layer | Falah | FLUENT | 2 | November 30, 2020 14:16 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
To thin boundary layer? | Luk | CFX | 3 | February 27, 2009 03:22 |
problem with boundary layer | Bharath | Main CFD Forum | 1 | July 11, 2008 09:06 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
