Mass sink and mass source in eulerTwoPhase application
Old   April 19, 2006, 02:08
Default Hi! Im trying to do a simul
newbee
Hi!
Im trying to do a simulation where water is heated to vapor. To do This im planing on using the eulerTwoPhase application with added heat equations. But since the water becomes vapor att the patches difined as heat sources, I need to take away water in the outer most cells i.e. mass sinks and create vapor in the same cells i.e. mass sources.
Does anyone know how to create such sources/sinks
Thanks
/Erik
Old   April 28, 2006, 19:24
Default Hello erik: Treat the mass
vatant is on a distinguished road
Hello erik:
Treat the mass and sink sources as momentum sources and add/subtract their values from the momentum equations. Its a pseudo approach but kinda throws light on the physics
Vatant
vatant is offline   Reply With Quote
Old   May 3, 2006, 06:42
Default Thanks a lot! I would like
newbee
Thanks a lot!
I would like to make this phase shift at one of the walls. Do you also know how to edit this so that it looks like vapor is created at the walls and not with a even distribution on the cross section area? i.e. I probably have make these equations on the cells closest to the wall.
best regards
/Erik Arlemark
Old   July 9, 2006, 07:15
Default Hello again, I got a bit di
newbee
Hello again,
I got a bit disoriented when trying to make out the code for twoPhaseEulerFoam. Could you or perhaps someone else help me find the momentum equation (is it the one in Ueqns.H?) and maybe point out where to add resp. subract with mass sources in order to simulate creation of vapor.
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 17:53
mass source and mass sink for multi-component frank CFX 0 May 14, 2008 11:55
help on mass sink using CEL function buhkuh CFX 0 March 18, 2008 23:57
mass sink UDF H FLUENT 1 November 8, 2004 22:44
help on UDF mass source shao1 FLUENT 2 July 11, 2002 20:36
