Question about gamma intgerpolation scheme
Old   July 26, 2010, 10:22
Default Question about gamma intgerpolation scheme
Antonio Martins
titio is on a distinguished road
Send a message via MSN to titio Send a message via Skype™ to titio
Hi foamers,
I have used recently the gamma interpolation scheme for convection terms, with some sucess I must say, in a flow problem where stress problems are relevant. However, in some cases the simulation crashes and I need to use other method.
I wonder if this a problem of the parameters I use in the method. In particular, in use gammaV 0.5 for the flow convective term and gamma 0.5 for other convective term but associated with extra stresses.
I know that lowering the parameter I should be getting more precision but less stability. But today I read in the forum some posts (http://www.cfd-online.com/Forums/ope...e-help-me.html) where the gamma method is used as gamma01 0.2 and gamma201 1.
Sincerely I am puzzled because I thought that gamma could not used with a constant larger than one, and I do not understand what means the numbers in front of th keyword.
Can someone tell me where I can get more information on the usage of gamma? A site with documentation wouls be great, only if the rules of capitalism did not interfere with that.
Regards,
António Martins
titio is offline   Reply With Quote
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
Definition of limiter function for central dirrerencing scheme sebastian_vogl OpenFOAM Running, Solving & CFD 0 January 5, 2009 11:08
Fundamental problem with Gamma scheme dominik_christ OpenFOAM Running, Solving & CFD 3 August 29, 2008 08:24
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Scheme documentation and question Mickaël Perrin FLUENT 0 July 4, 2002 05:21
