Adjusting kepsilon model
Old   April 12, 2005, 05:39
Default Hi, at our institute we did
Fabian Braennstroem
braennstroem is on a distinguished road
at our institute we did some modifications in fluent for the standard k-epsilon model via 'user defined functions'.
The simplest ones were just to modify the source terms.
Doing those modifications should be pretty easy in OpenFoam too; at least I expect that for an opensource code.
Now, I took a look at the files in
OpenFOAM-1.1/src/turbulenceModels/incompressible/kEpsilon
there are two sections for the dissipation and kinetic energy eqn.
Is this the only place I should care when adjusting the model or are there more to look at?
Then a Allwmake for the source should do the job to integrate the new code!?
Best Greetings!
Fabian
braennstroem is offline   Reply With Quote
Old   April 12, 2005, 08:09
Default You are right. All the code sp
Mattijs Janssens
mattijs is on a distinguished road
You are right. All the code specific to the incompressible k-epsilon is in that directory.
Better even would be to create a copy of those files and rename them (and the class inside them). Make sure you change the TypeName in the .H file as well. Compile them (change Make/files) and you'll have your own turbulence model.
mattijs is offline   Reply With Quote
Old   April 12, 2005, 09:52
Default Hi Mattijs, thanks! That so
Fabian Braennstroem
Hi Mattijs,
thanks! That sounds great!
I think that helps to convince my Prof. using it :-)
Greetings!
Fabian
KEpsilon model k_oldTime not working harly OpenFOAM Running, Solving & CFD 2 December 10, 2008 13:13
Modify kEpsilon model harly OpenFOAM 5 December 3, 2008 17:43
About kEpsilon turbulence model osimonsimon OpenFOAM Running, Solving & CFD 10 April 24, 2008 02:52
NACA0012 Study kepsilon Model pda OpenFOAM Running, Solving & CFD 1 March 11, 2008 03:12
mshaADD A NEW RELATION TO kepsilon MODEL msha OpenFOAM Running, Solving & CFD 3 January 6, 2008 07:06
