SimpleFoam for laminar flow
Old   April 14, 2005, 14:15
Default Hi, If I want to run a lamina
Ho Hsing
hsing is on a distinguished road
If I want to run a laminar flow problem with simpleFoam, what kind of parameters I need to provide. It seems to require wallFunction. Here is the erro message
--> FOAM FATAL IO ERROR : keyword wallFunctionCoeffs is undefined in dictionary ....
hsing is offline   Reply With Quote
Old   April 14, 2005, 14:26
Default You don't need to provide any
henry is on a distinguished road
You don't need to provide any parameters for the laminar "turbulence model" but the base class will read the wall-function parameters but they won't be used.
henry is offline   Reply With Quote
Old   April 14, 2005, 14:37
Default Thanks, So, in the file of /c
Ho Hsing
Thanks,
So, in the file of /constant/turbulenceProperties,
once I set:
turbulenceModel laminar;
turbulence off;
it REALLY solve the laminar problem.
Old   April 14, 2005, 14:39
Default Yes
Yes
SimpleFoam pressure driven flow gzink OpenFOAM Running, Solving & CFD 1 July 2, 2013 14:23
SimpleFoam as Newtonian laminar flow solver titio OpenFOAM Running, Solving & CFD 2 March 8, 2013 04:44
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet gabriel OpenFOAM Running, Solving & CFD 16 September 30, 2009 18:20
Steady incompressible laminar flow using simpleFoam yongshenglian OpenFOAM Running, Solving & CFD 0 October 29, 2008 15:28
SimpleFoam as laminar solver anja OpenFOAM Pre-Processing 3 April 5, 2007 09:28
