May 26, 2009, 03:50 |
Periodic GGI, How to
David Sponiar
Rep Power: 17 |
Hello to FOAMing users,
may I ask you to show me how to set up case with periodic boundary condition (periodic GGI), which are implemented in OF1.5-dev. Here is typical picture (see below) with testing case. Boundary conditions are set up like this: - inlet: total pressure - outlet: static pressure - stator: wallFunctions - periodic boundary condition: something like cyclic patch, which make possible to use non-conformal. In the later, I can post some mesh on the forum, which is prepare for using periodic ggi. Many thanks in advance, David |
Periodic boundary condition | Arif | FLUENT | 3 | March 9, 2017 01:18 |
periodic flows | Phil | FLUENT | 14 | May 16, 2013 07:21 |
Why can't I make the boundaries periodic? | Alina | FLUENT | 5 | April 12, 2012 14:06 |
Periodic GGI | cosimobianchini | OpenFOAM Running, Solving & CFD | 10 | August 9, 2007 04:59 |
Must periodic oscillation give periodic results? | zonexo | Main CFD Forum | 6 | May 13, 2007 15:36 |
