Running in Parallel on cluster
Old   November 2, 2010, 09:15
Default Running in Parallel on cluster
NewFoamer is on a distinguished road
I'm trying to run a cache on my school cluster. Currently I'm issuing following command:
mpirun --hostfile system/machines -np 6 pimpleFoamScalar -parallel
With my hostfile:
XXX@top.nbi.dk slots=2 max-slots=2
XXX@charm.nbi.dk slots=2 max-slots=2
XXX@bottom.nbi.dk slots=2 max-slots=2
Which gives me following error:
[top.nbi.dk:18796] btl: tcp: attempting to connect() to address 130.225.212.8 on port 260
[top.nbi.dk][[19986,1],0][btl_tcp_endpoint.c:638:mca_btl_tcp_endpoint_complete_connect] connect() to 130.225.212.8 failed: No route to host (113)
From the google-searched I've done, I believe I have to properly set the --mca to something, but I've thus far been unsuccessful in doing so properly. I'm new to OpenMPI, and do not have a lot of experience with network interfaces etc.
Any help or clues as how to debug the problem would be appreciated!
Thank you.
NewFoamer is offline   Reply With Quote
Old   November 2, 2010, 10:57
falcao is on a distinguished road
There is a OpenFoam cluster receipe, in the second page, in this same forum.
http://www.cfd-online.com/Forums/ope...am-solved.html
The translation to English is immediately below.
falcao is offline   Reply With Quote
Old   November 2, 2010, 11:04
This does not solve my problem - The machines share the same network drive and I've decomposed, made the hostfile etc. correctly.
Old   November 3, 2010, 16:20
Robertas N.
r08n is on a distinguished road
[top.nbi.dk][[19986,1],0][btl_tcp_endpoint.c:638:mca_btl_tcp_endpoint_comple te_connect] connect() to 130.225.212.8 failed: No route to host (113)
This looks like a network problem (misconfiguration?). First of all, check if you can
connect from one node of the cluster to any another node; e.g., like this:
telnet 130.225.212.8 260; if you get this message "no route to host", check the network configuration.
r08n is offline   Reply With Quote
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 08:53
Script to Run Parallel Jobs in Rocks Cluster asaha OpenFOAM Running, Solving & CFD 12 July 4, 2012 22:51
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
