Error in running simpleFoam
Old   August 1, 2011, 06:13
Default Error in running simpleFoam
mouvanal
mouvanal is on a distinguished road
Can any one help me in running simplefoam?
Iam trying to simulate a diesel injector using simpleFoam and getting the following error.
Starting time loop
Time = 1e-07
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0142123, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0414204, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0415188, No Iterations 1
--> FOAM FATAL ERROR:
request for surfaceScalarField phiv from objectRegistry region0 failed
available objects of type surfaceScalarField are
3
differenceFactors_
phi
weightingFactors
From function objectRegistry::lookupObject<Type>(const word&) const
in file /appl/OpenFOAM/OpenFOAM-1.6.x/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 140.
FOAM aborting
I am new to openfoam ,so please help me.
Regards
mouvanal
mouvanal is offline   Reply With Quote
Old   August 1, 2011, 07:15
Dima Risch
dima is on a distinguished road
hi mouvanal
i think simpleFoam is not the right solver to simulate a dieselInjection
if you are looking for a steady particle tracking -> LTSReactingParcelFoam (openfoam 2.0) could be the right solver
but there are not exact the same injection models like in dieselFoam or sprayFoam (openfoam 2.0)
regards, Dima
dima is offline   Reply With Quote
Old   August 1, 2011, 07:23
mouvanal
Hello Dima,
Thank you for you reply.
I am using simpleFoam only to get the initial solution and the flow field.
After that i want to run cavitating Foam.
..... Can you help on this error message....and how can i get waya with it.
Regards
Mouvanal
Old   August 1, 2011, 07:45
Dima Risch
ah ok, thought you tried to inject something by using simpleFoam
so i am new to openfoam too, and that error message deosn't tell me that much to figure out the error location
did you some modification to any source code?
EDIT: not "pressure p" -> phi would be solved in the next step so something might be wrong to that
maybe you have changed the include statement for phi in the createField.H
Old   August 4, 2011, 06:58
Kripal
kripalpariyangat is on a distinguished road
Can you tell me more about the problem. As far as i understood, you are trying to initialise P T U k epsilon values using simpleFoam. If possible upload your case file.
kripalpariyangat is offline   Reply With Quote
Problem running simpleFoam on a multi element airfoil vinz OpenFOAM Running, Solving & CFD 18 April 11, 2013 11:26
Problem running wmake on simpleFoam Greg Givogue OpenFOAM Installation 4 April 23, 2011 20:40
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 09:42
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
