feature or bug - deltaT issue
Like Tree1Likes
Old   January 9, 2012, 11:11
Retired Super Moderator
Bruno Santos
You can open another bug report with a feature request
Old   January 9, 2012, 17:11
Alberto Passalacqua
You can re-open the bug report I think (scroll down the page).
Alberto Passalacqua
Old   January 10, 2012, 03:38
Bruno Santos
Nope, only the original poster can re-open his/her own bug report. And I've reported before about this and... see for yourself: http://www.openfoam.com/mantisbt/view.php?id=228
Old   January 10, 2012, 08:51
Alberto Passalacqua
Hmm. I add this as a reason to prefer bugzilla to mantis ;-)
Alberto Passalacqua
Old   January 25, 2012, 18:57
Bruno Santos
Hi Alberto and Daniel,
I think mantis has an option for this... but I'm not 100% certain about this
By the way, to close the loop on this thread, a proper solution has been implemented for the issue that lead to the creation of this thread! Seen here: http://www.openfoam.com/mantisbt/view.php?id=382#c950 - the aforementioned commit is this one: https://github.com/OpenFOAM/OpenFOAM...e6cf8aa2c9bf39
Apparently the solution was a lot simpler than I first deduced... I thought there would be far more logical/cyclic issues with these variables, but I didn't look deep enough into an actual solution
Best regards,
Bruno
Old   January 25, 2012, 19:19
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
It's good to see Henry's revision.
    if (timeDict.readIfPresent("deltaT", deltaT_))
    // Read and set the deltaT only if timestep adjustment is active
    // otherwise use the deltaT from the controlDict
    if (controlDict_.lookupOrDefault<Switch>("adjustTimeStep", false))
        deltaTSave_ = deltaT_;
        deltaT0_ = deltaT_;
            deltaT0_ = deltaT_;
To change deltaT, "Go to controlDict" is a user's most natural selection.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   November 1, 2012, 02:19
Default What would be the reason for this
  #27
Suranga Dharmarathne
sdharmar is on a distinguished road
Hi Bruno, Daniel, Albreto and others,
I created tempPimpleFoam solver adding T field into basic pimpleFoam. And I tested it for pitzDaily tutorial case. But when I run the actual case it gave me the following error massage after running few iterations.
deltaT = 1.58835e-65
--> FOAM Warning :
From function Time:erator++()
in file db/Time/Time.C at line 1010
Increased the timePrecision from 145 to 146 to distinguish between timeNames at time 0.00166302
Time = 0.001663021666070488464861387711835050140507519245 147705078125
I could see that deltaT is keep on reducing and timePrecision value was adjusting in every timestep.
Sorry I can not attach the test case since the forum file size is very small.
Any idea would be appreciated.
Best regards,
Suranga.
sdharmar is offline   Reply With Quote
Old   October 23, 2019, 17:48
Default similar problem
  #28
Brett
Bdew8556 is on a distinguished road
Hey guys,
I'm getting super small time steps:
circa 1x10^-8 when I've set my deltaT to 0.001
Anyone know why its doing this?
Also does anyone have any best practice tips for getting a fireFoam simulation to run a bit faster? for example can you get by with a course mesh? any parameters in fvSchemes or fvSolution that you would recommend?
I'm aware LES solvers take a long time to solve but mine is taking a bit too long I think.
This is my fvSolution file:
| \\ / O peration | Version: dev |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
"(rho|rhoFinal)"
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0;
p_rgh
solver GAMG;
tolerance 1e-6;
relTol 0.1;
smoother GaussSeidel;
p_rghFinal
$p_rgh;
tolerance 1e-6;
relTol 0;
ph_rgh
$p_rgh;
"(U|Yi|k|h)"
solver PBiCGStab;
preconditioner DILU;
tolerance 1e-6;
relTol 0.1;
nSweeps 1;
"(U|Yi|k|h)Final"
$U;
tolerance 1e-6;
relTol 0;
Ii
solver GAMG;
tolerance 1e-4;
relTol 0;
smoother symGaussSeidel;
maxIter 1;
nPostSweeps 1;
G
solver PCG;
preconditioner DIC;
tolerance 1e-04;
relTol 0;
PIMPLE
nNonOrthogonalCorrectors 2;
pRefPoint (1 0 0.25);
pRefValue 84437;
momentumPredictor yes;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 0;
hydrostaticInitialization yes;
nHydrostaticCorrectors 5;
relaxationFactors
equations
"(U|k).*" 1;
"(CH4|O2|H2O|CO2|h).*" 1;
Followed by fvSchemes:
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss LUST grad(U);
div(phi,K) Gauss linear;
div(phi,k) Gauss limitedLinear 1;
div(phi,Yi_h) Gauss multivariateSelection
O2 limitedLinear01 1;
C12H24 limitedLinear01 1;
N2 limitedLinear01 1;
H2O limitedLinear01 1;
CO2 limitedLinear01 1;
h limitedLinear 1;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
div(Ji,Ii_h) Gauss upwind;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
Bdew8556 is offline   Reply With Quote
Old   August 8, 2020, 01:07
Michael@UW is on a distinguished road
I have a similar question about time control when using overPimpleDyMFoam in OpenFOAM v2006. It's weird that I lose the data for the last few time steps when I try to write out data every 10 time steps.
I tried different combinations but none of them work.
Option 1:
deltaT                      0.00001028; // small time step to reduce CFL
writeControl             adjustableRunTime;
writeInterval            0.0001028;  //  every 10 time steps to save space
runTimeModifiable    yes; // changing to 'no' doe not work either
adjustTimeStep	      no;
timePrecision          10; //time precision is enough
Option 2:
deltaT                      0.00001028;
writeControl             timeStep;
writeInterval            10;
runTimeModifiable    no;
adjustTimeStep	      no;
timePrecision           10;
Option 2:
deltaT                      0.00001028;
writeControl        runTime;
writeInterval            0.0001028; // = 10 time steps
adjustTimeStep	      no;
timePrecision           10;
Here is the complete controlDcit for the first one:
application     overPimpleDyMFoam;
startFrom		latestTime;
deltaT          0.00001028;
startTime		0.0073502;
endTime		0.0147004;
//0.294008
//writeControl    timeStep;
//writeInterval   10;
//writeControl    runTime;
//writeInterval   0.0001028;
purgeWrite      0;
writeFormat     binary;
writePrecision  10;
writeCompression off;
timeFormat      general;
timePrecision   10;
adjustTimeStep	no;
maxCo 2.0;
maxDeltaT 0.0001028;
Here is the time directories (first column) generated. The second column is the time difference calcualted by hand (current - previous time step). It shows the deltaT is correct. But the last one is 0.0072988 which should be 0.0073502 as set in controlDict. That means the data for the last 5 time steps are not outputed. But when I the log file shows the solver goes through all the time steps including Time = 0.00733992.
time	 time difference
0
0.0001028	0.0001028
0.0002056	0.0001028
0.0003084	0.0001028
0.0004112	0.0001028
0.000514	0.0001028
0.0006168	0.0001028
0.0007196	0.0001028
0.0008224	0.0001028
0.0009252	0.0001028
0.001028	0.0001028
0.0011308	0.0001028
0.0012336	0.0001028
0.0013364	0.0001028
0.0014392	0.0001028
0.001542	0.0001028
0.0016448	0.0001028
0.0017476	0.0001028
0.0018504	0.0001028
0.0019532	0.0001028
0.002056	0.0001028
0.0021588	0.0001028
0.0022616	0.0001028
0.0023644	0.0001028
0.0024672	0.0001028
0.00257	0.0001028
0.0026728	0.0001028
0.0027756	0.0001028
0.0028784	0.0001028
0.0029812	0.0001028
0.003084	0.0001028
0.0031868	0.0001028
0.0032896	0.0001028
0.0033924	0.0001028
0.0034952	0.0001028
0.003598	0.0001028
0.0037008	0.0001028
0.0038036	0.0001028
0.0039064	0.0001028
0.0040092	0.0001028
0.004112	0.0001028
0.0042148	0.0001028
0.0043176	0.0001028
0.0044204	0.0001028
0.0045232	0.0001028
0.004626	0.0001028
0.0047288	0.0001028
0.0048316	0.0001028
0.0049344	0.0001028
0.0050372	0.0001028
0.00514	0.0001028
0.0052428	0.0001028
0.0053456	0.0001028
0.0054484	0.0001028
0.0055512	0.0001028
0.005654	0.0001028
0.0057568	0.0001028
0.0058596	0.0001028
0.0059624	0.0001028
0.0060652	0.0001028
0.006168	0.0001028
0.0062708	0.0001028
0.0063736	0.0001028
0.0064764	0.0001028
0.0065792	0.0001028
0.006682	0.0001028
0.0067848	0.0001028
0.0068876	0.0001028
0.0069904	0.0001028
0.0070932	0.0001028
0.007196	0.0001028
0.0072988	0.0001028 // last one dumped
By the way, the delataT in uniform/time shows consistent with that in controlDict.
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "0.0072988/uniform";
    object      time;
value           0.00729879999999991612; // this value looks weired
name            "0.0072988";
index           710;
deltaT          1.028e-05; // same value as that in controlDict
deltaT0         1.028e-05; // same value ... but in scientific format
I hope Bruno, Alberto or some others can have a look at my problem. I have been stuck in this problem for a few days. I will add more information if needed.
Michael@UW is offline   Reply With Quote
Old   August 8, 2020, 01:34
After posting, I just found I changed the endTime during the run incorrectly which made the endTime not a multiple of writeInterval though it is a multiple of deltaT. That's why the data were not outputed.
Sorry about that!
Feature Capture Problem brunob ANSYS Meshing & Geometry 0 July 21, 2011 04:17
Meshing related issue in Flow EFD appu FloEFD, FloWorks & FloTHERM 1 May 22, 2011 08:27
for developers: bug or feature? akarak Siemens 0 October 22, 2009 02:47
Maybe a bug in CFX12.0 BETA? frank CFX 4 November 26, 2008 18:08
Bug or a feature of OF15 rafal OpenFOAM Bugs 5 July 25, 2008 05:25
