Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Validating OF, turbulent flow over flat plate
Old   July 3, 2012, 05:29
Default Validating OF, turbulent flow over flat plate
Thilo Michels
Thilo is on a distinguished road
Hi!
I would like to calculate the turbulent flow over a flat plate by using pisoFOAM. My main concern is to get a correct boundary layer. Unfortunately I don't have a strong cfd background and I'm looking for some advices about what to change in my model.
To give you a start, my mesh sizes are:
normal to boundary: y+ 1.0 - 20 with 3 cells in the range y+ 0 - 10
flwo direction: y+ = 20
normal to flow direction: y+ = 7
The domain is rectangular, the sice is: 1x1x0.1 m
In my first model I used a turbulent flow at the inlet to get a boundary layer. Unfortunately this doesn't give me a good boundary layer as the velocities near the wall are to high.
Can someone give me a hint about how what I have to change to get a fully resolved boundary layer? Does someone has experience about how long my model should be to get a boundary layer which is comparable with the boundary layer of a channel flow?
Thank you very much in advance.
Thilo
Thilo is offline   Reply With Quote
compressible laminar flow over flat plate varunjain89 Main CFD Forum 19 April 18, 2019 06:07
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
compressible flow over a flat plate vigii FLUENT 2 January 3, 2012 07:12
Flow Over a Flat Plate recon9 CFX 1 January 20, 2011 21:09
Turbulent Flat Plate Validation Case Jonas Larsson Main CFD Forum 0 April 2, 2004 10:25
