Different material properties
Old   September 2, 2012, 10:02
Default Different material properties
Pierre
pilafa is on a distinguished road
I have a simple problem: One rectangular domain of "fluid 1", on top of another rectangular domain of "fluid 2".
The interface between the two domains is fixed.
My problem is to define the material properties on those 2 domains.
I thought it would be trivial, but it seems it's not.
Other post on this forum discuss this, but any seems to solve this issue.
(see, for example: http://www.cfd-online.com/Forums/ope...same-mesh.html)
Note that the cellZones of my two domains are already defined.
Any clue?
Many thanks
pilafa is offline   Reply With Quote
Old   September 2, 2012, 15:03
Retired Super Moderator
Bruno Santos
Greetings Pierre,
Mmm... indicating "material properties" is a bit ambiguous... it really depends on what you are trying to solve!
For example, the tutorial "heatTransfer/chtMultiRegionFoam/multiRegionLiquidHeater" has the following mesh zones:
  • bottomWater - it's a liquid fluid (or water vapor, I honestly didn't check )
  • heater - it's solid
  • leftSolid - it's solid
  • rightSolid - it's solid
  • topAir - it's air
But this establishes that there is an intermediate solid interface, thus not allowing direct fluid contact.
Now, if you want 2 fluids in direct contact, but that do not mix due to their properties... uh... I'm not sure. My guess is that you should take a look at the "multiphase" sub-folder located in the "tutorials" folder.
Best regards,
Bruno
Old   September 3, 2012, 02:09
akidess's Avatar
Anton Kidess
If you're interface is fixed, then either cht-multiregionfoam or icofoam with a small changes to the code to allow for spatially varying transport properties is what you want.
- Anton
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
material properties
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Fluent is not accepting Modification in Material properties er.mkumar FLUENT 0 September 1, 2012 14:24
error message cuteapathy CFX 14 March 20, 2012 06:45
How to add more material properties sarahsun CFX 1 October 27, 2009 07:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
