[swak4Foam] Bug in groovyBC in parallel computation
Like Tree2Likes
  • 2 Post By gschaider
Old   February 11, 2012, 07:15
Default Bug in groovyBC in parallel computation
Aleksey Rukhlenko
Aleksey_R is on a distinguished road
Send a message via ICQ to Aleksey_R
Greetings, dear Foamers.
I found a bug which seems to be connected with groovyBC. If in groovyBC expressions the "max" and "min" statements are used, the parallel run of simpleFoam and pisoFoam fails.
This bug is specific for OF-1.6-ext. I tried the same case in OF-2.1.0 (with some changes specific for 2.1.0 version) and anything worked OK.
I attach an example case. It runs simpleFoam OK on a single core but fails in parallel simpleFoam run.
Best regards, Aleksey.
Aleksey_R is offline   Reply With Quote
Old   February 11, 2012, 08:51
Retired Super Moderator
Bruno Santos
Greetings Aleksey,
Bernhard might not fix this if it's not reported on the dedicated bug tracker for swak4Foam: http://sourceforge.net/apps/mantisbt...?project_id=10
Make sure that you pick swak4Foam as the project to where you report, since it is embedded into Extend's main project.
On another note... I think I saw swak4Foam being integrated directly into 1.6-ext's git repo... have you seen or are you using that version?
Best regards,
Bruno
Last edited by wyldckat; February 12, 2012 at 13:44. Reason: sorry, misspelled your name...
Old   February 11, 2012, 09:30
Aleksey Rukhlenko
Thank you for your reply, Bruno.
I've submitted a bug N 123:
https://sourceforge.net/apps/mantisb...iew.php?id=123
The swak4foam was downloaded by command:
svn checkout https://openfoam-extend.svn.sourcefo...ies/swak4Foam/
OF-1.6-ext I downloaded by means of:
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext
and there were neither swak4foam nor groovyBC.
Old   February 11, 2012, 09:41
Bruno Santos
Hi Aleksey,
Ah, now I remember, it's on a branch, apparently pending approval. Try this:
git merge origin/bgschaid/feature/swak4Foam
Then:
wmake all src/swak4Foam
wmake all applications/utilities/swak4Foam
Best regards,
Bruno
Old   February 11, 2012, 10:20
Aleksey Rukhlenko
I've checked the attached case using branched swak4foam. The same behaviour - simpleFoam works OK on single core and fails on parallel run.
Old   February 11, 2012, 14:52
Philippose Rajan
philippose will become famous soon enough
Hi and a Good Evening :-)!
This issue that you have seen is to do with the OpenFOAM-1.6-ext version of OpenFOAM.
I posted this as a bug report quite a while ago under the GroovyBC topic, but after discussing it with Bernhard, it turned out to be an issue with the "-ext" version of OpenFOAM.... specifically, to do with "pTraits".
However, can you give me some more details regarding the crash you are having with simpleFoam?? I use GroovyBC with simpleFoam for parallel simulations quite often. Though I get a warning that the "min" or "max" functions return a zero and that the average will be taken (cant remember the exact warning), the simulations work out fine, and the results are also good.
By the way..... I am using the latest version of OpenFOAM-1.6-ext from the Git repository.
Have a nice day!
Philippose
philippose is offline   Reply With Quote
Old   February 12, 2012, 07:26
Aleksey Rukhlenko
Thank you for your reply.
Honestly, the logs are not informative. I attach the log and the terminal output.
By the way, does the attached in this thread case runs on your system?
File Type: txt terminal_output.txt (842 Bytes, 16 views)
Old   February 12, 2012, 13:41
Philippose Rajan
Hi again,
I just tried the case you had posted on this thread with OpenFOAM-1.6-extm and you are right..... it does not work.
Initially I thought it might be because the decomposition also cut up the patches into different domains... but I dont think that is the case. Atleast, the decomposition that I got from "decomposePar" had all the patches intact in either one of the two parts.
I hope this post catches Bernhard's attention..... He may have something more to say about the issue. I think he is already aware of it.
Sorry I could not help further....
Have a nice day ahead :-)!
Philippose
Old   February 13, 2012, 19:01
Assistant Moderator
Bernhard Gschaider
Originally Posted by wyldckat View Post
Hi Aleksey,
Then:
Best regards,
Bruno
There are good reasons that this branch is currently not merged into the default-branch (I just put it there for discussion). The swak-sources that are there don't differ from regular swak (so this wouldn't fix the problem discussed).
Old   February 13, 2012, 19:04
Assistant Moderator
Bernhard Gschaider
Originally Posted by philippose View Post
Hi again,
Philippose
Had a quick look at it and can reproduce the problem. Further communications on this will be through the bug on the Mantis (link see above)
Old   September 13, 2012, 02:40
toolpost is on a distinguished road
Hi !
I am getting the same error in simpleFoam solver of OpenFoam1.6ext with parabolicVelocity boundary condition. My case is a simple laminar pipe flow with a constriction and I am trying to run it on an 8-core cpu. The case is tested for single and multiple cores with surfaceNormalfixedvalue bc and found working. but, when parabolicVelocity boundary condition is used, normal solution without decomposing is working fine. but, when tried to decompose it and run in parallel, it ended up with similar errors mentioned above.
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.0105602, No Iterations 2
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.0903589, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0875971, No Iterations 1
[entropy:2277] *** An error occurred in MPI_Recv
[entropy:2277] *** on communicator MPI_COMM_WORLD
[entropy:2277] *** MPI_ERR_TRUNCATE: message truncated
[entropy:2277] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
mpirun has exited due to process rank 0 with PID 2277 on
node entropy exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
[entropy:02276] 1 more process has sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[entropy:02276] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
I have swake4Foam installed, but not used in this particular case. So I think this error is not related to groovyBC.
Any advice would be greatly appreciated... and thanks a lot for your time.
Regards
Jabir
toolpost is offline   Reply With Quote
Old   September 13, 2012, 04:36
Assistant Moderator
Bernhard Gschaider
Originally Posted by toolpost View Post
Hi !
Time = 1
Regards
Jabir
To be sure remove the swak-stuff from the libs entry (then I can plead "I'm not to blame")
I think it can't be the parabolic-BC as the velocity has already been successfully solved. The problem seems to occur during the pressure solution. Are you using any AMG-type solver for that. Just for testing replace it with one of the CG-solvers.
Other than that in my experience that kind of error usually occurs because of an inconsistently compiled OF-version (because of an update after which you chose only to compile some libraries for instance). Sounds like snake oil but sometimes a complete recompilation helps.
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 13, 2012, 07:15
Thanks for your quick response..
Previously, I haven't included the libs in my controlDict file and so I thought there is no connection between this error and swak4Foam. right? Anyways, now I completely removed swak4Foam and the same error is still there.. So, I think it is a good news for you..
No. I am not using AMG.
solvers
    p
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.01;
    U
        solver           PBiCG;
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0.1;
So, what to do next? Do you think a complete re-compilation/installation solve this issue?
Thanks a lot for your time.
Regards,
Jabir
Old   September 13, 2012, 10:56
Assistant Moderator
Bernhard Gschaider
Previously, I haven't included the libs in my controlDict file and so I thought there is no connection between this error and swak4Foam. right? Anyways, now I completely removed swak4Foam and the same error is still there.. So, I think it is a good new for you..
solvers
    p
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.01;
    U
        solver           PBiCG;
        tolerance        1e-05;
        relTol           0.1;
Regards,
Jabir
I'm afraid recompilation will not help.
You mentioned the parabolic-BC before. That is the last thing I can think of. Replace that with a normal fixedValue. If the simulation then runs OK then probably the min/max in parallel is the problem
Old   September 13, 2012, 23:01
Good morning!
I already tested the case with "surfaceNormalFixedValue" and it is working fine. I mentioned it in my first post. The "parabolicVelocity" runs in single core simulation, but fails for parallel case.
Thanks for your time and consideration.
Regards,
Jabir
Old   September 15, 2012, 09:05
Bruno Santos
Greetings to all!
@Jabir: Can you provide an example based on one of the tutorial cases? This way we can more easily try and replicate the problem you're getting.
Best regards,
Bruno
Old   September 15, 2012, 11:45
Good evening!
Yes. I tried with pitzDaily case with laminar flow assumption and the same errors appeared again. The case file is attached. Please have a look at the 0/U file. Both inlet bcs are fine with single core simulation. But in parallel run, the parabolicvelocity crashes as said above.
Thanks for your help.
Regards,
Jabir
Old   September 16, 2012, 04:22
Bruno Santos
Hi Jabir,
OK, only now did I come to the conclusion that the problem is with the "parabolicVelocity" BC itself, not groovyBC
Therefore, I think this should be reported at http://sourceforge.net/apps/mantisbt...?project_id=11, namely project "OpenFOAM-ext release", along with the test case you provided!
As for a quick fix, have a look at the tutorial "incompressible/simpleFoam/pitzDailyExptInlet", where you can find in the folder "constant/boundaryData/inlet/" that the values at the "inlet" are being defined for each point on the patch.
It may be a bit annoying having to define them manually or with the help of another utility, but for now this would be the somewhat-quickest solution.
Best regards,
Bruno
Old   September 17, 2012, 23:40
Good morning Bruno!
Thanks a lot for your help and suggestions. So, the problem comes from parabolicVelocity bc, and not from groovyBC. I shall post a bug report in the link you provided.
I have checked it. The procedure of specifying individual velocities at each points looks tedious, but as you said it would be the quickest solution. I am going to give it a try.
Thanks again for your time and help.
Regards,
Jabir
Old   September 18, 2012, 07:50
Assistant Moderator
Bernhard Gschaider
Good morning Bruno!
Regards,
Jabir
Something that might make it less tedious is funkySetBoundaryFields. This allows you to set boundary fields (not only the value but everything that accepts a uniform/nonuniform value like the inletValue) statically with an expression. Basically the idea would be to set the parabolic inlet for a fixedValue in the serial case with it and then decompose it (this would avoid this unfortunate min/max-bug)
There is an example-dictionary that comes with swak4Foam
wyldckat and toolpost like this.
bug, groovybc, parallel, pisofoam, simplefoam
Fluent parallel computation using Xeon duo-processor with CFD occupation below 50% zhujj09 FLUENT 1 October 19, 2016 15:02
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
the speed of parallel computation for over 3 million grid is very slow liujmljm SU2 7 June 27, 2014 16:45
Run in parallel: bug or what? novyno OpenFOAM Running, Solving & CFD 0 November 10, 2009 10:34
load balancing in parallel computation shyamdsundar Main CFD Forum 0 September 2, 2009 23:53
