July 13, 2013, 01:21 |
Density_based turbo with OpenFoam 2.2.0
DongHo
Rep Power: 12 |
Hi ! Foamers
I have been using OpenFoam 2.1.1 and am moving to 2.2.0. By the way, I have questions about 2.2.0. For this time, I want to simulate a transonic turbine blade in 3D using density based compressible solvers with SRF and MRF on it. Which one is the best one for this in OpenFoam 2.2.0? It seems that there is a density based compressible solver for a movign mesh like sonicDyMFoam in OpenFoam 2.2.0, but, not a density based compressible solver with SRF. I know that there was OpenFoam 1.6 ext version with densitybasedturbo module including several transoni SRF or MRF solvers. How can I use this module on OpenFoam 2.2.0? I want to know a procedure in detail to use it. I will appreciate it if somone lets me know those things. Thank you. |
February 13, 2014, 01:27 |
Rep Power: 12 |
Hi
Even I am in need of this information as I installed OpenFOAM 2.2.1 and want foam-extend-3.0 to simulate Radial flow Turbine ? Anybody know how to do it ? |
February 15, 2014, 12:20 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@sam.ho: I'm having trouble understanding what exactly you want to do. Is it:
Bruno
February 17, 2014, 22:47 |
Rep Power: 12 |
Hi Bruno,
I am want to simulate Radial flow turbine. As i understood that this problem can't be solved using OpenFOAM 2.2.2 solvers. Hence we need to use DensityBasedturbomsolver ? Anybody has any idea how to add these extension and run the tutorials ? |
March 2, 2014, 06:05 |
Bruno Santos
Rep Power: 128 |
Hi Sam,
If you need to install foam-extend 3.0, you can find instructions here: http://openfoamwiki.net/index.php/In...oam-extend-3.0 As for having more than one OpenFOAM version/variant: http://openfoamwiki.net/index.php/In...with_the_Shell It's probably not easy to transfer certain solvers from foam-extend 3.0 to OpenFOAM 2.3, because the codes are somewhat different in certain parts. As for installing the toolkit "DensityBasedTurbo", run these commands: Code:
mkdir -p $FOAM_RUN cd $FOAM_RUN/.. git clone git://git.code.sf.net/p/openfoam-extend/DensityBasedTurbo DensityBasedTurbo cd DensityBasedTurbo/src ./Allwmake Code:
cd ../run edit: I've created a wiki page for this repository: http://openfoamwiki.net/index.php/Ex...sityBasedTurbo Best regards, Bruno
Last edited by wyldckat; March 2, 2014 at 07:05. Reason: see "edit:" - finally created the wiki page for it |
OpenFOAM - Validation of Results | Ahmed | OpenFOAM Running, Solving & CFD | 10 | May 13, 2018 18:28 |
OpenFOAM 2.2.0 installation on scientific-linux | kulkarni Harshawardhan | OpenFOAM Installation | 1 | March 20, 2013 13:38 |
forceCoeffs (OpenFOAM 2.2.0) gave another values of Cd in comparison results2.2.1 ! | lavrov | OpenFOAM Post-Processing | 0 | March 15, 2013 09:12 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
The OpenFOAM extensions project | mbeaudoin | OpenFOAM | 16 | October 9, 2007 09:33 |
