Define Re Number with rhoCentralFoam
Like Tree2Likes
  • 1 Post By Artur
  • 1 Post By eRzBeNgEl
Old   November 1, 2013, 09:29
Default Define Re Number with rhoCentralFoam
eRzBeNgEl is on a distinguished road
Hi guys,
as a beginner, how can I define the Reynoldsnumber for rhoCentralFoam
For icoFoam I choosed for Re=10 following parameters:
U=(1 0 0)
nu = 0.1
D = 1
=> Re=20
How can I do this for rhoCentralFoam?
Thank you
eRzBeNgEl is offline   Reply With Quote
Old   November 4, 2013, 04:12
Artur's Avatar
Artur
Artur will become famous soon enough
Reynold's number is a fundamental flow property and is independent of what solver or code you're using. So the answer would be: you define it in the same way as you did in the example you've posted (I think you have an error there since 1/0.1 = 10, not 20). Still, since you are asking about rhoCentralFoam, which is a compressible solver, you are probably interested in compressibility and so Mach number of your problem will also be important, amongst other things.
Good luck with your case,
A
eRzBeNgEl likes this.
Artur is offline   Reply With Quote
Old   November 4, 2013, 07:14
Thanks, got it already. Re=20 was a silly typo of me :-)
Artur likes this.
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
how to define the number of CPUs passionfruit FLUENT 2 June 16, 2011 15:53
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
