floating object
Like Tree1Likes
  • 1 Post By Maimouna
Old   November 5, 2013, 08:42
Default floating object
ok
Maimouna is on a distinguished road
Dear OpenFOAM users,
can you help me please to solve the error that I got when run
run/tutorials/multiphase/interDyMFoam/ras/floatingObject
blockMesh was fine, but when I run interDyMFoam, it gives me the following error
maimouna@maimouna-desktop:~/OpenFOAM/maimouna-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/floatingObject$ interDyMFoam
| \\ / O peration | Version: 2.2.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.1-57f3c3617a2d
Exec : interDyMFoam
Date : Nov 05 2013
Time : 13:16:34
Host : "maimouna-desktop"
PID : 3096
Case : /home/maimouna/OpenFOAM/maimouna-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/floatingObject
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Duplicate entry alphatJayatillekeWallFunction in runtime selection table fvPatchField
#0 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+ 0x25) [0x7f43ed0633b5]
#1 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so(+0x8f3f9) [0x7f43e5e9c3f9]
#2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7f43f1455306]
#3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7f43f14553df]
#4 /lib64/ld-linux-x86-64.so.2(+0x13ada) [0x7f43f1459ada]
#5 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f43f1455176]
#6 /lib64/ld-linux-x86-64.so.2(+0x1331a) [0x7f43f145931a]
#7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf26) [0x7f43ec8f6f26]
#8 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f43f1455176]
#9 /lib/x86_64-linux-gnu/libdl.so.2(+0x152f) [0x7f43ec8f752f]
#10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7f43ec8f6fc1]
#11 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x 45) [0x7f43ed05c405]
#12 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_ 8fileNameEb+0x63) [0x7f43ecdc4233]
#13 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_ 10dictionaryERKNS_4wordE+0x9d) [0x7f43ecdc54fd]
#14 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7ar gListES3_S3_+0x63a) [0x7f43ecde301a]
#15 interDyMFoam() [0x422bbf]
#16 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f43ebd4676d]
#17 interDyMFoam() [0x42db5d]
#1 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so(+0x8f4a1) [0x7f43e5e9c4a1]
#1 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so(+0x8f44d) [0x7f43e5e9c44d]
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementLaplacian
--> FOAM FATAL IO ERROR:
cannot find file
file: /home/maimouna/OpenFOAM/maimouna-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/floatingObject/0/pointDisplacement at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 73.
FOAM exiting
What this means? How solve it?
Thanks a lot for your helping.
Maimouna is offline   Reply With Quote
Old   November 6, 2013, 10:36
Samuele Z
samiam1000 is on a distinguished road
If you open the Allrun file, you discover that after "blockMesh" you have to give some topoSet commands, befor running the simulation.
Have you done this?
samiam1000 is offline   Reply With Quote
Old   November 6, 2013, 10:44
ok
Dear Samuele,
I didn't do it. How can I do it please?
Old   November 6, 2013, 11:28
Samuele Z
Simply open the Allrun file in the case dir and copy the command in your terminal.
Old   November 7, 2013, 04:47
ok
Dear Samuele,
I have this Allrun file in my case
#!/bin/sh
cd ${0%/*} || exit 1 # run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Set application name
application=`getApplication`
runApplication blockMesh
runApplication topoSet
runApplication subsetMesh -overwrite c0 -patch floatingObject
cp -r 0.org 0 > /dev/null 2>&1
runApplication setFields
runApplication $application
# ----------------------------------------------------------------- end-of-file
What command I have to copy?
I tried, and all log files are there but the same error comes again.
What's the problem?
Old   November 7, 2013, 05:01
Samuele Z
Hi.
Well, you can either run the command ./Allrun in the case dir, or giving all the commands, one after the other. In your case:
blockMesh
topoSet
setFields
interDyMFoam
Old   November 7, 2013, 05:41
ok
Hi dear,
sorry for disturbing you many times, but when run this command
gives me the following error,
maimouna@maimouna-desktop:~/OpenFOAM/maimouna-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/floatingObject$ subsetMesh -overwrite c0 -patch floatingObject
Exec : subsetMesh -overwrite c0 -patch floatingObject
Date : Nov 07 2013
Time : 10:32:33
PID : 3736
nProcs : 1
Create time
#0 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+ 0x25) [0x7f8b6d3b53b5]
#1 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so(+0x8f3f9) [0x7f8b67ca23f9]
#2 /lib64/ld-linux-x86-64.so.2(+0xf306) [0x7f8b6f801306]
#3 /lib64/ld-linux-x86-64.so.2(+0xf3df) [0x7f8b6f8013df]
#4 /lib64/ld-linux-x86-64.so.2(+0x13ada) [0x7f8b6f805ada]
#5 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f8b6f801176]
#6 /lib64/ld-linux-x86-64.so.2(+0x1331a) [0x7f8b6f80531a]
#7 /lib/x86_64-linux-gnu/libdl.so.2(+0xf26) [0x7f8b6cc48f26]
#8 /lib64/ld-linux-x86-64.so.2(+0xf176) [0x7f8b6f801176]
#9 /lib/x86_64-linux-gnu/libdl.so.2(+0x152f) [0x7f8b6cc4952f]
#10 /lib/x86_64-linux-gnu/libdl.so.2(dlopen+0x31) [0x7f8b6cc48fc1]
#11 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6dlOpenERKNS_8fileNameEb+0x 45) [0x7f8b6d3ae405]
#12 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_ 8fileNameEb+0x63) [0x7f8b6d116233]
#13 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam14dlLibraryTable4openERKNS_ 10dictionaryERKNS_4wordE+0x9d) [0x7f8b6d1174fd]
#14 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam4TimeC1ERKNS_4wordERKNS_7ar gListES3_S3_+0x63a) [0x7f8b6d13501a]
#15 subsetMesh() [0x439d99]
#16 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f8b6c09876d]
#17 subsetMesh() [0x43c9cd]
#1 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so(+0x8f4a1) [0x7f8b67ca24a1]
#1 /opt/openfoam221/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so(+0x8f44d) [0x7f8b67ca244d]
Reading cell set from c0
Adding exposed internal faces to patch floatingObject
Subsetting field nut
Subsetting field k
Subsetting field p_rgh
Subsetting field alpha1
size 94848 is not equal to the given value of 96000
file: /home/maimouna/OpenFOAM/maimouna-2.2.1/run/tutorials/multiphase/interDyMFoam/ras/floatingObject/0/alpha1 from line 18 to line 94888.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.1/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
Old   November 7, 2013, 06:12
Samuele Z
I am running it and it works, for me.
So, I suggest you to enter the case and give the command
./Allclean
and then
./Allrun
Do you still have the error?
Old   November 7, 2013, 07:35
ok
It still running. Many thanks.
If any problem, I will let you know.
Best regards
Old   November 7, 2013, 07:50
Samuele Z
Ok.
Good luck,
Samuele
Old   November 7, 2013, 07:58
ok
Unfortunately, it still gives me error when I interDyMFoam.
I followed all steps.
./Allclean
./Allrun
blockMesh
topoSet
subsetMesh -overwrite c0 -patch floatingObject ( the problem starts here)
setFields
interDyMFoam
What can I do then?
Old   November 7, 2013, 10:24
ok
When I applied ./Allrun all time step was fine, but find problem with paraFoam?
After ./Allrun, shall I need to apply:
blockMesh
topoSet
setFields
interDyMFoam
or no need?
Old   November 8, 2013, 08:44
Samuele Z
If you execute the Allrun, it does all the stuff for you. Hence, if you give:
./Allclean
[to clean the case]
and then
./Allrun
that's it. You have finished your simulation.
Otherwise, you can clean the case (with ./Allclean) and then execute the command by yourself.
Is it clear, now?
Old   November 8, 2013, 11:09
ok
Thanks very much. It works fine now.
Kind regards
samiam1000 likes this.
engineFoam with layers - pressure problems when adding layers mturcios777 OpenFOAM Running, Solving & CFD 23 January 4, 2023 21:56
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Inserting a floating object on a restart RileyJ FLOW-3D 0 October 24, 2011 16:05
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
