cmake: No such file or directory
Old   April 27, 2009, 20:58
Default cmake: No such file or directory
David Gaden
marupio is on a distinguished road
Everything works when I install OpenFOAM 1.5 on ubuntu 8.10 (64 bit) except for paraFoam. When I try to view the cavity flow results, it opens, but there's nothing useful being displayed, and it crashes when I try to do streamlines. So I assume it is my paraView conflicting with Qt (4.4.3 on my installation).
Here's the thing that really gets me. When I try to compile paraview, it doesn't understand the cmake command in the script. Typing 'cmake' in the terminal gives:
bash: /home/dave/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin/cmake: No such file or directory
But it's there. The cmake application and directories are there, exactly where it says it isn't. Does anyone have any idea what's going on here?
marupio is offline   Reply With Quote
Old   April 28, 2009, 18:11
Default update
David Gaden
I got cmake to behave. All I did was update my video driver with ATI supplied drivers. That seems totally unrelated, but that's the only thing I did between [not-working] and [working] reboots.
Old   May 1, 2009, 02:29
J. Cai
chiven is on a distinguished road
how about the results of running foamInstallationTest?
please run the command in the terminal:
which cmake
I have ever install cmake by myself. you also can do it, it is very simple.
chiven is offline   Reply With Quote
Old   May 1, 2009, 10:21
Default Before and after:
David Gaden
I have 2 installations of Ubuntu - one where I (somehow) solved the problem, and the other where I haven't yet solved it.
Problem solved machine:
which cmake
Problem not solved machine:
which cmake
cmake
Old   May 1, 2009, 16:15
Default Update
David Gaden
I just installed Ubuntu on my laptop. Ran into the cmake problem again. Switching to the ATI supplied drivers solved it. Bizare.
Old   June 15, 2009, 13:11
Matteo Carpentieri
mcarpe is on a distinguished road
Hello, I've got the same problem on a 64 bit Ubuntu machine. Unfortunately I cannot try the solution above because I've got an nvidia card
Any other solution? It seems a really odd problem.....
mcarpe is offline   Reply With Quote
cmake, parafoam
OpenFOAM 15 and openSUSE 111 paraview works OK alberto OpenFOAM 10 March 6, 2009 05:52
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
