Mesh quality improvement
Old   February 14, 2012, 05:29
Default Mesh quality improvement
Disabled
anon_a is on a distinguished road
Hello Foamers
I have a simple mesh generated by blockMesh, which however contains some "bad" cells. I generate sets for these cells with "checkMesh -allTopology -allGeometry" and can visualize them in paraView after isolating them with "setSet -batch makeCellSets.setSet" and "subsetMesh badCells". However, I have not been able to fix them.
Is there a non-manual (scriptable) way of using the foam mesh manipulation utilities in which I could fix the "bad" cells? I am looking for a combination of the mesh manipulation tools that can improve the quality of my mesh, mostly in terms of simulation stability.
Sorry if the question is rather vague or this information has been posted elsewhere but I have not been able to find it.
anon_a is offline   Reply With Quote
Old   February 20, 2012, 08:19
Disabled
Bump. I would appreciate an answer, even if it's negative.
I wonder what I am doing so wrong and no one answers my posts
Old   February 20, 2012, 09:04
Retired Super Moderator
Bruno Santos
Greetings anon_a,
AFAIK, no, there is no utility in OpenFOAM that fixes bad cells. The standard is to do things right the first time around.
Nonetheless, there are a few things that might come in handy in some situations:
  • "applications/utilities/mesh/advanced/removeFaces" - should be able to remove excess faces that are between cells.
  • "applications/utilities/mesh/advanced/modifyMesh" - can do limited mesh manipulation, such as collapsing edges, which might be useful for taking out skew faces.
But, if the problem you are getting is with blockMesh, then it's you who is doing things wrong Try:
paraFoam -block
This can help you visualize and diagnose what you might be wrongly defining on "blockMeshDict"
Best regards,
Bruno
Old   February 20, 2012, 10:47
Disabled
Ok, I was sure I was the one doing it wrong :-D
My geometry is slightly more complicated than I can handle with blockMesh anymore, so I guess I will try something else.
I was asking because I would prefer to adapt the mesh to the changes in the flow along with time. For example, create the blockMesh in the beginning, run the simulation for 1ms, refine/remove cells, correct the "bad" cells, resume the simulation for 1 ms and so on. I am sure someone must have done something similar, right?
Thanks a lot for the answer Bruno!
Old   February 20, 2012, 11:59
Bruno Santos
Ah, then that's a whole other ball game...
See the tutorials that use dynamic meshes, because there are several that use point displacement. But I've yet to understand how they work
Old   February 20, 2012, 12:08
Disabled
I was afraid you were going to say that...
So the keyword here is point displacement, I will look for that.
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[ICEM] Tetra mesh quality before and after prism layer Chander ANSYS Meshing & Geometry 0 December 25, 2011 22:04
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
