adapt offset cylinder model for les turbulence
Old   August 19, 2010, 21:10
Red face adapt offset cylinder model for les turbulence
Charlie
shackman287 is on a distinguished road
I am trying to adapt the offsetCylinder mesh to work with a les turbulent model. As of now I have created a new folder combining the mesh from offset cylinder and the 0 and system folders from the pisoFoam les model (incompressible). The code can generate the mesh through blockmesh, but when I run the code using the pisoFoam solver I get the following error.
keyword left is undefined in dictionary "home/...../lescylinder/0/p: :boundaryField"
I looked at the P file and there is no "left" term found. I believe this is created from the (non-congruent) constant and 0 system files but I am not sure.
Any advise would be much appreciated.
shackman287 is offline   Reply With Quote
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 20:21
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
