paraFoam crash
Like Tree2Likes
  • 2 Post By FabOr
Old   July 27, 2010, 07:03
Default paraFoam crash
FabOr is on a distinguished road
after starting paraFoam I get following error message:
***:~/OpenFOAM/***-1.6/run/Vak200$ paraFoam
created temporary 'Vak200.OpenFOAM'
fileName::stripInvalid() called for invalid fileName H2(Kopie)~
For debug level (= 2) > 1 this is considered fatal
Aborted
I appreciate any hints!
Thanks
FabOr is offline   Reply With Quote
Old   July 27, 2010, 18:45
Retired Super Moderator
Bruno Santos
Greetings FabOr,
The message seems self explanatory, but I'll break it down for you:
fileName::stripInvalid() - This method tries to remove unwanted characters from file names. Since the file is meant to be read, then it will only check if the name is kosher, i.e., valid.
H2(Kopie)~ - this name seems to have one too many invalid characters! If I'm not mistaken, the tilde '~' is a bad one, and the parenthesis '()' might be two other characters that aren't acceptable. My guess is that you copied the file in the same folder as a backup - H2(Kopie) - but your text editor also created another backup of your backup - H2(Kopie)~.
Sooo... the moral of this error: keep the contents of the time folders sanitized
Best regards,
Bruno
Old   August 3, 2010, 04:00
Hi wyldckat,
thanks for your answer.
Unfortunately i donīt have any copied files in my time directories.
To be sure that it is not a problem connected to the file names,i have renamed all the H2-files to H2. but i get the same error message again...
maybe it is important that i use chemkin and reactingFoam!?
best regards,
FabOr
Old   October 20, 2010, 21:42
Question was a solution found?
lth
lth's Avatar
lth
lth is on a distinguished road
Hi FabOr,
Wonder if a solution to this error was found? I have the exact problem for a case i ran and want to view in paraFoam.
Thank you for any insight, Lori
Originally Posted by FabOr View Post
Hi wyldckat,
best regards,
FabOr
lth is offline   Reply With Quote
Old   October 21, 2010, 03:43
Hi Lori,
wyldckat was right.
iīve found files which were invalid named, but they were invisible.
youīve got to type " strg+h " to see the invisible files, then you have to delete the invalid ones.
hope that helps.
best regards
IsabelleT and StefanW like this.
Old   October 21, 2010, 10:20
lth
lth's Avatar
lth
Hi FabOR
works, thank you for the post!!! -Lori
[OpenFOAM] pointVectorField in ParaFoam s_braendli ParaView 0 April 22, 2010 08:36
[OpenFOAM] Segmentation fault with paraFoam and paraview 3.6.1 on Fedora 11 32 and 64 bit nanes ParaView 2 September 11, 2009 09:12
[OpenFOAM] Parafoam basic questions qtian ParaView 0 July 20, 2007 11:52
[OpenFOAM] ParaFoam OF 14 decomposed cases philippose ParaView 4 April 18, 2007 05:17
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit sek ParaView 4 August 17, 2006 16:26
