Defining "cyclic" B.C. problem
Old   September 28, 2010, 09:27
Default Defining "cyclic" B.C. problem
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
i made a 3-D mesh with Gambit for backward facing step. i want define front and back boundary condition as "cyclic". the problem is after writing polymesh by fluent3DMeshToFoam and creation of polyMesh i can't use pisoFoam because of error.
typing checkMesh led to:
HTML Code:
Create time
Create polyMesh for time = 0
--> FOAM FATAL ERROR:
face 0 area does not match neighbour 102850 by 139.834% -- possible face ordering problem.
patch:frontAndBack my area:5.42258e-07 neighbour area:9.60035e-08 matching tolerance:0.001
Mesh face:5438360 vertices:4((0.49476 0.1143 -0.0127) (0.5 0.1143 -0.0127) (0.5 0.114197 -0.0127) (0.49476 0.114197 -0.0127))
Neighbour face:5541210 vertices:4((0.0644278 0.1143 0.0127) (0.0635 0.1143 0.0127) (0.0635 0.114197 0.0127) (0.0644278 0.114197 0.0127))
Rerun with cyclic debug flag set for more information.
maysmech is offline   Reply With Quote
Old   September 28, 2010, 09:42
Simon Lapointe
Simon Lapointe is on a distinguished road
I've run into this problem before. I suggest you create your cyclic patch in OF afterwards using "createPatch". Instead of defining one cyclic patch in Gambit, just make two patches that you'll merge with "createPatch" once the mesh in imported. When creating the mesh on these patches, use "Link Face Meshes" in Gambit to have a good face ordering.
Simon Lapointe is offline   Reply With Quote
Old   September 28, 2010, 11:35
maysmech's Avatar
By using Link Face Meshes of gambit the problem of cyclic B.C is solved.
Now, the problem is ib boundary file of polyMesh folder frontAndBack_shadow is added and i don't know what should be it defined in U, P, ... of 0 folder.
Old   September 28, 2010, 11:41
Simon Lapointe
Is frontAndBack_shadow your cyclic patch created using "createPatch" ? If so, the boundary definition should be "type cyclic" for all variables.
Old   September 28, 2010, 11:44
maysmech's Avatar
no, it is export of gambit. i don't know how to use createPatch
Old   September 28, 2010, 14:36
maysmech's Avatar
i searched whole of forum and didn't find any acceptable answer for cyclic B.C in openFoam when importing from Gambit.
Is it any idea?
Old   September 29, 2010, 00:03
Travis Carrigan
tcarrigan is on a distinguished road
I've seen this problem before as well. The issue is with the grid. In order to use the cyclic bc, the two patches must be point matched. The fact that you are getting tolerance and face ordering problems is because your two cyclic patches are not point matched, meaning they don't match up EXACTLY.
If you happen to be using the 1.5-dev version, I suggest switching to cyclicGgi which does not require the two patches to be point matched. It relies on weighting factors and allows for more freedom when constructing the grid, which is really useful for turbo applications.
tcarrigan is offline   Reply With Quote
Old   September 29, 2010, 01:32
maysmech's Avatar
i am using OpenFOAM 1.7
Old   September 29, 2010, 02:42
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Originally Posted by maysmech View Post
Is it any idea?
create cyclic BC in Gambit works as importing mesh from other software, unless you have a specific OF exporter, as in Pointwise. Thus, I will suggest to look in ./applications/utilities/mesh/manipulation/createPatch/createPatchDict. There is an example there that shows how to use createPatchDict. If you still have problems, post here and I will answer.
Cheers
mad
maddalena is offline   Reply With Quote
Old   September 29, 2010, 03:12
maysmech's Avatar
Thanks for your reply.
You mean i should create mesh with Pointwise instead of Gambit?
Old   September 29, 2010, 03:34
maddalena's Avatar
maddalena
Of course, NO! If you use Pointwise, you can create cyclics directly on the software and then export into OF without any adding steps.This is a feature of Pointwise. I do not know if it is possible or not with other software.
In any case, you can create your mesh with your preferred software, define two separate patches in it, export in OF and create the cyclic using createPatchDict. What you must assure is that the two patches are exactly equals.
Clearer?
mad
Old   September 29, 2010, 03:49
maysmech's Avatar
Two questions:
What should be it defined in gambit: periodic,wall,...?
Is it needed to link faces(Front and back) in Gambit?
Old   September 29, 2010, 05:03
maddalena's Avatar
maddalena
Never used Gambit before for this kind of problems... however:
It does not matter. They should be patches in OF, so you can define them as you like and then change them as patch in constant/polymesh/boundary.
What do you mean? in your BC definition or in mesh creation? In BC definition: no, the two boundaries must be defined separately in order to use createPatch. In mesh creation: yes, if this help to keep faces correspondence.
mad
Old   September 30, 2010, 03:18
Jiang
panda60 is on a distinguished road
Dear maddalena ,
two kinds of periodic boundary condition exist, one is translational, another is rotational. I know the meaning of rotational, but for translational, should define "separationVector(-2289 0 0)", do you konw the meaning of separationVector ?
panda60 is offline   Reply With Quote
Old   September 30, 2010, 03:56
maddalena's Avatar
maddalena
The separationVector is the distance between the two patches you want to connect.This kind of cyclic is useful if you have two patches that need to be connected in such a way that values on one patch are copied on the second patch. An example of this kind of usage is the Fan BC. More about the latter that can be found here.
Enjoy
mad
Old   October 2, 2010, 23:02
Jiang
Dear maddalena ,
Thans for your explanation, Now I unstand the meaning.
Old   March 11, 2011, 17:58
farhagim is on a distinguished road
Enjoy
mad
Hello Maddalena,
It seems that you are expert in Cyclic B.C. Would you please help me with my problem:
I create a 3D mesh(ex. cube) in Gambit, I linked the MEsh of front and Back face and make it periodic in Gambit) then I named it ex. periodic.1 and export as cube.msh.
Then I imported by fluent3DMeshToFoam to OF 1.7.1. it created two boundary in boundary file. periodic.1 &periodic.1_shadow. I changed the periodic.1_shadow to periodic.2 and use createPatch Dict. to create cyclic B.c. here is my createPatch Dict.
matchTolerance 1e-3;
// Do a synchronisation of coupled points.
pointSync true;
// Patches to create.
// If no patches does a coupled point and face synchronisation anyway.
patches
// Name of new patch
name periodic.2;
// Type of new patch
type cyclic;
// How to construct: either 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches
patches ("periodic.*");
// If constructFrom = set : name of faceSet
//set f0;
everythings was fine and I copied the new polyMesh file which was created after running createPatch in to my constant directory. I can run it in serial and works fine. But when I want to run it in Parallel I got this error. I have to mention that I use interDyMFoam for my case.
Selecting turbulence model type laminar
Reading g
Calculating field g.h
time step continuity errors : sum local = 8.951529e-06, global = -8.951529e-06, cumulative = -8.951529e-06
DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 9.610304e-11, No Iterations 492
time step continuity errors : sum local = 1.227278e-15, global = -3.512952e-18, cumulative = -8.951529e-06
Courant Number mean: 0.0008794369 max: 0.009276953
Starting time loop
Interface Courant Number mean: 3.106989e-06 max: 0.2330362
Courant Number mean: 0.04397184 max: 0.4638476
deltaT = 5e-05
Time = 5e-05
Selected 704 cells for refinement out of 405600.
--> FOAM Warning :
From function syncTools<class T, class CombineOp>::syncEdgeList(const polyMesh&, UList<T>&, const CombineOp&, const T&, const bool)
in file /home/farhangi/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/syncToolsTemplates.C at line 1311
There are decomposed cyclics in this mesh with transformations.
This is not supported. The result will be incorrect
Any help ??
Thanks,
Mehran
farhagim is offline   Reply With Quote
Old   March 14, 2011, 02:25
maddalena's Avatar
maddalena
Hi Mehran.,
--> FOAM Warning :
this sounds a little bit strange for me... Have you done some kind of mesh refinement? this is not a problem connected with cyclicBC itself... and in that case my "expertise" is not so useful..
mad
Old   March 14, 2011, 08:44
Alex
aloeven is on a distinguished road
Did you decompose with:
preservePatches (CyclicPatches);
This should be in system/decomposeParDict
The cyclic patches should be on the same processor. Looking at your error, you have you cyclic patches decomposed and distributed over multiple processors.
aloeven is offline   Reply With Quote
Old   March 14, 2011, 10:19
Hi Alex,
Yes After that error I use preservePatches (CyclicPatches); for decomposing. It works with Parrallel but the problem is now with reconstructing the Meshes. Since I am using interDyMFoam, First, I have to run reconstructMesh(because the mesh has been changed) and then reconstruct it. Here is the error that I got by running the reconstructMesh:
Merge tolerance : 1e-07
Write tolerance : 1e-07
Doing geometric matching on correct procBoundaries only.
This assumes a correct decomposition.
Found 8 processor directories
Reading database "testparallelcyclic/processor0"
Reading database "testparallelcyclic/processor1"
Reading database "testparallelcyclic/processor2"
Reading database "testparallelcyclic/processor3"
Reading database "testparallelcyclic/processor4"
Reading database "testparallelcyclic/processor5"
Reading database "testparallelcyclic/processor6"
Reading database "testparallelcyclic/processor7"
Setting master time to 0.239
Reading points from "testparallelcyclic/processor0" for time = 0.239
Reading points from "testparallelcyclic/processor1" for time = 0.239
Reading points from "testparallelcyclic/processor2" for time = 0.239
Reading points from "testparallelcyclic/processor3" for time = 0.239
Reading points from "testparallelcyclic/processor4" for time = 0.239
Reading points from "testparallelcyclic/processor5" for time = 0.239
Reading points from "testparallelcyclic/processor6" for time = 0.239
Reading points from "testparallelcyclic/processor7" for time = 0.239
Overall mesh bounding box : (-1.401849e-10 0 0) (0.23858 0.235 0.04)
Relative tolerance : 1e-07
Absolute matching distance : 3.372616e-08
Constructing empty mesh to add to.
Reading mesh to add from "testparallelcyclic/processor0" for time = 0.239
Adding to master mesh
Reading mesh to add from "testparallelcyclic/processor1" for time = 0.239
face 0 area does not match neighbour 2337 by 186.979% -- possible face ordering problem.
patcheriodic.2 my area:4.58316e-06 neighbour area:1.54214e-07 matching tolerance:0.001
Mesh face:423717 vertices:4((0.02625 0.079155 0.04) (0.02625 0.0864881 0.04) (0.025625 0.0864881 0.04) (0.025625 0.079155 0.04))
Neighbour face:426054 vertices:4((0.0529859 0.0342575 0.04) (0.053981 0.0342322 0.04) (0.0539878 0.0343869 0.04) (0.052991 0.0344122 0.04))
From function cyclicPolyPatch::calcTransforms()
in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 179.
FOAM exiting
Any idea why I got this message??
looking forward to hearing back from you,
Thanks,
MEhran
Problem in defining and using the deformation rate tensor titio OpenFOAM Running, Solving & CFD 0 November 19, 2009 12:50
which B.C. i should apply for this problem? raivish CFX 0 January 6, 2006 08:47
Mesh problem tuks CFX 4 May 18, 2005 14:07
problem in giving b.c kiran FLUENT 0 August 10, 2004 04:21
UDF 3D inlet b.c. problem Andrew FLUENT 4 May 25, 2004 04:24
