paraview stoped working
Old   November 27, 2010, 07:22
Default paraview stoped working
Benjamin Nwobodo
Benjy is on a distinguished road
Hi there,
After copying and recompiling the IcoFoam to my_icoFoam as directed in the OpenFOAM wiki "how to add Temperature to icoFoam" tutorial, the new solver runned successfully.
But unfortunately, running the paraFoam gives the following error:
benjy@benjy-laptop:~/OpenFOAM/benjy-1.7.1/run/my_icoFoam_cavity$ paraFoam
created temporary 'my_icoFoam_cavity.OpenFOAM'
/opt/openfoam171/bin/paraFoam: 142: paraview: not found
benjy@benjy-laptop:~/OpenFOAM/benjy-1.7.1/run/my_icoFoam_cavity$ ^C
The paraview does not also work when i try to run other cases from the tutorials.
I am new user of OpenFOAM and don't know what next to do.
Could anyone be of help to me in solving this problem?
Benjy is offline   Reply With Quote
Old   November 27, 2010, 07:36
Retired Super Moderator
Bruno Santos
Greetings Benjamin,
You are not alone on this a solution already exists: http://www.cfd-online.com/Forums/ope...not-found.html
Best regards and good luck!
Bruno
Old   November 27, 2010, 08:36
Benjamin Nwobodo
Hi Bruno,
million thanks for the help, it works now. But i get the following warning:
OpenGL Warning: Failed to connect to host. Make sure 3D acceleration is enabled for this VM.
Benjamin
Old   November 28, 2010, 09:23
Bruno Santos
Hi Benjamin,
Mmm... let me guess: you are using Ubuntu in a VirtualBox virtual machine? There should be an option in the virtual machine settings, for turning on 3D acceleration, although my experience with this has never been very good (but I only tried it in VMPlayer).
But if you are using Ubuntu in a real machine (i.e., not in a virtual machine), then you haven't installed the graphic card drivers.
Best regards,
Bruno
Old   November 28, 2010, 19:57
Benjamin Nwobodo
Hi Bruno,
You are right. i am using ubuntu in a vitualbox VM and have turned the 3D acceleration ON and it works now perfectly.
Thanks for the efforts.
Benjamin.
[General] Paraview nice animation PyGloo ParaView 4 June 7, 2012 12:34
working with paraview gandesk OpenFOAM 0 November 19, 2010 11:48
ParaView Stopped Working AlanR OpenFOAM 5 April 17, 2010 04:55
[OpenFOAM] ParaView 3.6.1 3D viewer not working will_avoid_comm_solvers ParaView 2 March 9, 2010 16:13
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
